facelift w204 c350; 300+hp, 7200rpm redline, anyone know the changes made?
Old Jul 12, 2011 | 03:25 AM
  #126
snacks's Avatar
2006 c230
Originally Posted by ejarry
Hi cpbeasley,
I saw on many blog on your installation.You put slk350 intake manifold on a c350... i would like to have more info about the ecu tuning. Did you find a way to remove error code? and my other question is about the throttle body... can i fit my 74mm the time to find a cheap ptice for a 82mm?
Thank you for your time.
ejarry
the 74mm t/b will not mate up to the new manifold. the closest you can do is an 80mm from an e55 i believe but you would have to have a machine shop make you an adapter plate to fit the smaller t/b.
the codes in question are stored codes and do not trigger a cel. specifically a p2008 i think or 2018. From what i remember it states that an intake runner flap is open.
essentially the ecu reads an open intake runner valve since the actual sensor has no port to plug into in the new manifold.
if you would like to speak to cpbeasley he's over in mbjunkies now.
