HELP POWER STEERING malfunctioning
Old Jan 19, 2011 | 11:07 PM
mlg's Avatar
mlg
06 C350 sport 6MT
finally found the dyno mode so set out for my virgin run of parking lot donuts on a 1/2 inch of snow. did about 4 donuts all in the same direction, suddenly the steering resistance is very hi , oh cr p! now the resistance is very high at slow speed with idle rpm, when u add rpms the steering resistance returns to normal and during regular speeds is normal, parking manuevers are arm wrestling unless i rev to 2-3k rpm, i sucked out the powersteering fluid from the resevoir, looked brown, and replaced w fresh fluid drove it 50 miles and repeated. seems to have helped ALITTLE, what did i do and how do i fix it?? what a bummer , a few donuts and now this, i thought benz still built a durable car, nver had a problem like this w my 92 500e porschades even after 165k miles. if ive fried the pump , how do i replace ??? and any suggs for inexpensive rebuilt sales sites r much appreciated, thanx, bummed out mike feel free to pm me
__________________
Old Jan 19, 2011 | 11:11 PM
cpbeasley's Avatar
"annoyance" and "self-righteousness", amoung others...
did this is exact thing after donuts in an ex-girlfriend's grand am (more like half donuts). required a new PS pump. warranty fix though. good luck.
Old Jan 20, 2011 | 12:23 AM
samaritrey's Avatar
Super Moderator
THE C350
MLG you are not the first or last to do some stupid *** driving and kill your PS pump if you look back into old threads you will see this. hopefully it is something else but i have a felling it is the pump.
Old Jan 20, 2011 | 01:07 AM
Utahkompressor's Avatar
W124, W203, W204, W251
My friend fried his PS pump while doing donuts too.
I guess if you don't keep holding the steering wheel all the way, it's fine!
But when you do, the pump will overheat.
Old Jan 20, 2011 | 02:17 AM
W203E35's Avatar
2006 C350 Sport 6MT
Damn what a burn. Doing a couple of doughnuts and Power Steering pump goes out. Suck big time...wonder why the pump is soo weak?
Old Jan 20, 2011 | 10:14 AM
Glyn M Ruck's Avatar
Super Moderator
Try turning the steering from lock to lock 5 times with the engine running to re-bleed the system & reset the steering angle sensor to keep the ESP happy. Make sure the reservoir is topped up after doing this.
If this does not work - it's a new pump.
The mechanics of this failure have never been plain to me but we know it happens. I think the steering system fights itself somehow causing cavitation/aeration/overheating of the fluid which screws the pump.
Don't do it again!
Old Jan 20, 2011 | 10:44 AM
BigBodyBenzC240's Avatar
...a panty dropper...
I had this same issue. The P/S pump malfunctioned while doing this and was shaving metal off down into my P/S fluid lines taking it to the rack and pinion and jacked it all up. I had to replace both the pump and the rack and $1600 later I have P/S again!! Woohoo!!
Old Jan 21, 2011 | 03:21 PM
mlg's Avatar
mlg
06 C350 sport 6MT
samarity, thanx for the sympathetic sentiments, thanx to otherrs for help,, ill try the 5x lock to lock manuever
Old Jan 21, 2011 | 05:36 PM
I tried the same thing lock to lock when my car did this and all it did was leave me with a great workout! Good luck with this issue, hope its not a severe as mine. Just note to self, if it isnt an AMG... dont attempt donuts in it!
Old Jan 21, 2011 | 05:39 PM
samaritrey's Avatar
Super Moderator
THE C350
hope there are no hard feelings like i said you are not the first or last with this problem good luck with it keep us updated
btw nice car 06 c350 Manual most would kill for that
Old Jan 21, 2011 | 06:27 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This is all over the forum. Doughnuts are the equivalent to russian roulette with the power steering system in these cars, and the W204 as well (someone on that side just killed their PS too).
There should be a sticky warning at the top of the forum warning people against this practice.
Old Jan 22, 2011 | 12:28 AM
mlg's Avatar
mlg
06 C350 sport 6MT
i agree, ive been on this forum for 7 years and ive NEVER seen a post warning of doing a few donuts, im very disapointed at mb for this engineering snafoo, yeah " engineered like no other ". if you make a car w a 260 hp engine w a stick and a dyno mode, duh someone is going to enjoy the car in a non grandpa way. a STICKY is definitely NEEDED !!!
Old Jan 22, 2011 | 08:22 AM
Super Moderator
Benz does not want us plebs to go into "dyno" mode. Can't blame them.
Old Jan 22, 2011 | 09:10 AM
LILBENZ230's Avatar
I concur 100%. It is not called "doughnut mode". The car has what Mercedes would consider for the buying public a stability program that cannot be defeated. That we have figured out how to hack the system doesn't mean their engineering is poor. It's really not designed for that sort of thing realistically. 268HP, non-defeat ESP, and an open diff. It's no engineering SNAFU. No disrespect intended, but it is technically user error.
By the way, I've been on the forum less than three years and have seen dozens of posts with this same scenario: One enables dyno mode, one does doughnuts, one replaces power steering pump in swarm of profanity. It needs to be more widely known that doughnuts are expensive gambles.
Old Jan 22, 2011 | 10:11 AM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I'm still trying to figure out the mechanics of why this happens?
Old Jan 22, 2011 | 10:59 AM
Crna Mechka's Avatar
12 E350 4Matic Sport
It's a Benz man...not a Mitsubishi. Why would you do that to your ride? I know it's fun and all but why risk the trouble of screwing a component ofthe car up? After all...repairs for Benz are not cheap! All the best man, good luck.
Old Jan 22, 2011 | 11:36 AM
cpbeasley's Avatar
+1
benzy the bear says: be careful out there, only you can prevent power steering failures
Old Jan 22, 2011 | 06:33 PM
Super Moderator
You & me
Old Jan 23, 2011 | 12:41 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
..i thought benz still built a durable car..
Formidable pressure can be generated for the steering’s hydraulic circuitry. Requesting extended ~110 bar/1595 psi (during full-lock) from the pump is a death knell.
Dilettante PO had mine replaced under warranty. She apparently didn’t know any better.
Old Jan 23, 2011 | 02:04 AM
mlg's Avatar
mlg
06 C350 sport 6MT
im sure no owner of a c63, cl65, or sl55 have ever done a donut, come on u all , benz makes durable and hi performance cars, but they screwed up here. i wouldnt be suprised if this happened to a saturn, but to a SPORT car from a company whose mantra is -the best or nothing, give me a break.
Old Jan 23, 2011 | 05:38 AM
LILBENZ230's Avatar
AMG cars are different animals altogether than your car. Sorry, it wasn't made for it - yes it sucks and it will cost you but you did something with it that it wasn't designed for.
Would you be pissed off if you had taken it off-roading and damaged something? Not designed for that either.
Old Jan 23, 2011 | 08:02 AM
Super Moderator
Yep! & ZF make some of the finest PS units on the planet.
Old Jan 23, 2011 | 11:21 AM
samaritrey's Avatar
Super Moderator
THE C350
wait i can't take my c320 off road oh ****. I use to drive it though a field in the mud and even following a jeep up a atv trail to get to a camp site.
Remember this was with the stock c320 suspension so the car had great ground clearance. Oh and when I wrecked my baby and drove it up a bank high centering it on an embankment (Fing Deer) backed it down scratching lots of stuff but no real damage. Still cost 2k+ to fix though lol. our cars are more capable then most give them credit for or i am crazy
Old Jan 23, 2011 | 02:42 PM
mlg's Avatar
mlg
06 C350 sport 6MT
one last comment befor i put this dead horse to rest---im 51 yo and had the most satisfying automotive experienceof my life w my daily driver 92 500e (the one that had a non AMG 500sl drivetrain shoehorned into a 300e body ) from 75-150k miles. i drove it like i stole it, polo position tires lasted 7-8k miles and i never had a mechanical failure like this . i guess they just dont make em like they used to.
to Glyn m : thanx for the suggestion, i tried the 5 lock maneuver but i dont think it helped much, soooooooooo, i gues the p/s pump is fried. any suggestions on where to get a remanufactured one, and is there a post on how to replace it. id like to try. a family member is ill and money is tight w medical bills. thanx, mike
btw, i think this can all be summarized in a STICKY so others dont have to suffer, for 203 and 204 owners.
also, for 204 owners, i think i saw a recall for p/s pump
Old Jan 23, 2011 | 03:09 PM
cpbeasley's Avatar
mlg... i see your point but...
what you did (putting it in dyno mode) was kinda like removing the rev limiter, reving it to 8K rpm (equivalent of subjecting the PS to pressure above what it can handle) and spinning a rod bearing (blowing your pump) and then declaring that it wasnt built well enough because after all it's a high performance luxury car.
