C320 wont start!
Cut the story short, i bought a new battery, checked all the fuses that were 'engine electronics' and it still does the same thing. Help!!
Starter relay S in front SAM
Starter solenoid
Starter motor itself.
First check relay S
https://mbworld.org/forums/attachmen...eft-engine.pdf
EDIT - hope it's not the EIS - thats expensive.
Also check fuses 31,48,52,53,54,57
I removed the relay, and tried to turn the engine over without the relay in. The car continued to do the same old thing, even with the relay out. Does this mean its bad?
Put a jumper wire on it...if it starts, then the relay is bad.
If it does not start, then the relay is okay and something else is bad.
(history): 100K even on odometer but <1k is mine and suddenly yesterday it cranked normal for a split second and stopped. I push started the car in 2nd (got a alt/batt warning light doing that). I've now discovered the engine is bathing in oil (cam seal recall that I have to figure out how to deal with).
Battery is strong. Fuses are all good all around. Tried jumping the starter solenoid below with a screwdriver while tapping with a hammer (think I was doing it correctly by touching the big fat positive + terminal with the other one next to it with the little wire ), got a couple of little sparks (some hard to hear electrical motor whirring noise) and a couple of clicks just like when it stopped working originally. Sounding like a solenoid issue? Maybe there is oil in the starter wires and I'm going to take it apart right now to clean it up with crc electrical motor cleaner.
As a side note, I have a 05 srt-6 too and am now wondering how long before the fun begins and I better check the boards for more info...
