Removing struts do i remove this bolt
Old Jan 28, 2011 | 06:43 PM
Xhale707's Avatar
C320 2002
Okay im confused i was reading this
https://mbworld.org/forums/c-class-w...ml#post2254601
And im not sure if i remove this bolt at the top or not.. I dont want the spring to shoot off. I have all the bolts undone at the bottom but the thing just doesn't wanna come out. do i unscrew this bolt?
Its stuck
Old Jan 28, 2011 | 06:50 PM
hcoronado's Avatar
2021 GLC300 4Matic
yes you have to remove it. Dont worry, the spring will not come apart if you remove.
Old Jan 28, 2011 | 06:53 PM
Xhale707's Avatar
C320 2002
okay hope i don't die if im back in 20 mins im alive =D
Old Jan 28, 2011 | 07:01 PM
Xhale707's Avatar
C320 2002
Blah im scared are you sure??
Old Jan 28, 2011 | 07:06 PM
Xhale707's Avatar
C320 2002
Okay i got it haha i unscrewed it and then took off the plate and screwed it back in and poped it out to be 100% sure haha thank you again!!!
Old Jan 28, 2011 | 07:07 PM
M-bENZ's Avatar
Corrolla
Xhale707,
Do you have aftermarket Amp/Sub installed ?
Andy
Old Jan 28, 2011 | 10:36 PM
ambit's Avatar
09 CLK550
The center should be a 7mm allen key/hex. Hold that steady and use a 22mm (or 24mm?) socket on the nut.
Once the nut is off the strut assembly should drop out and you can remove the black plate.
Make note of how the 'hat' at the top (strut bearing) is oriented so it sits right on reassembly.
Old Jan 28, 2011 | 10:38 PM
Xhale707's Avatar
C320 2002
Originally Posted by M-bENZ
Xhale707,
Andy
yeah i do i have a 1200 watt rms 12 inch sub woofer installed on my bose system. I dont have the subwoofer in my trunk right now because the box weights like almost 100 pounds.
Old Apr 1, 2011 | 11:01 AM
pejaife's Avatar
2014 E350 4Matic
Its stuck
Do you remember the allan bolt and nut wrench sizes you used for upper wheel hub assembly?
