DIY: Installing ghostrider's camber kit
Old 02-16-2011, 10:12 AM
RX729's Avatar
W203 W210 SW20 FC3S TBSS
Nice writeup, It'll come in handy when I do it myself in the future...
Old 04-04-2011, 12:02 PM
blue960's Avatar
W210 - V6'02 / W163 - V6'02
im using H&R spring and 19"x10 on the rear .. squat a bit .. when going thru a bump at high speed i can feel the rear end swaying when touching the asphalt.. will this camber kit solve the problem?
Old 05-18-2011, 09:01 PM
vdubpower's Avatar
i drive them all, fast and hard
sorry for the rookie Q, but is the purpose of these kits to induce neg. camber, ?? and if so , why?
Old 05-18-2011, 09:28 PM
phister's Avatar
06 C230 SS 6spd
When you lower your car it produces a negative camber which will cause the inside of the tire to wear quicker then the outside. The kit will correct this and you can adjust the camber back to OEM spec.
Old 05-18-2011, 09:35 PM
vdubpower's Avatar
ok, makes sense, i just lowered my w126 last week, H R springs, new bilstein shocks, but my rear suspension doesnt have anything to adjust for alighments, only the front has tie rods
pics on benzworld of the car
Old 06-14-2011, 11:26 AM
DaytonaJae's Avatar
02 SLK32 AMG, 07 E350 Sport
Graphics broken on the install
Old 06-14-2011, 01:51 PM
  #32
phister's Avatar
06 C230 SS 6spd
graphics?
Old 06-14-2011, 05:07 PM
  #33
anthonyy's Avatar
2006 C280
Step 1: purchase camber kit from Ghostrider
Step 2: accidentally smash a torque wrench into your forehead during installation
Step 3: get 5 stitches
Step 4: bring the camber kit to a race shop and get it installed for $150 with alignment
btw... I do suck at DIYs... but the camber kit is awesome
Old 06-14-2011, 06:07 PM
  #34
Super Moderator
samaritrey's Avatar
THE C350
sorry dude that sucks. How much did the stitches cost?
Old 06-15-2011, 12:35 AM
  #35
phister's Avatar
06 C230 SS 6spd
lol you must have been sticking your head in the wheel well to get his in the head but that does suck. Knock on wood I've never had any bones break just dislocated some things haha
Old 06-15-2011, 12:38 PM
  #36
anthonyy's Avatar
2006 C280
no intention of thread jacking here!
Lucky, my uncle is an oral surgeon. I go to him for all my minor stitching needs!
Phister, you make DIYs look so easy because you are obviously very handy... DAMN YOU!
Old 06-17-2011, 10:32 AM
  #37
DaytonaJae's Avatar
Originally Posted by phister
graphics?
Sorry, it seems that my company's firewall blocks the image host that your DIY pics in the first post are hosted at.
I tried on a different computer on the outside and they came up.
Great post, very informative, thanks for the write up.
Jae
Old 06-17-2011, 12:54 PM
  #38
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Ouch, sorry about the stitches but can you share what shop did the install and alignment in the bay area?
I've had many shops promise more than setting the toe and letting it go, and then
when I get there, they refuse to adjust anything except the toe.
I have the camber bolts in the front, no one will touch them.
This would make the whole camber thing much more attractive to do knowing it's not
going to cost as much as a set of tires. And that there's a shop that doesn't have their heads
up their ***** and will actually do a proper alignment.
Old 06-17-2011, 01:58 PM
  #39
anthonyy's Avatar
2006 C280
Sure thing C230, here is their Yelp link:
http://www.yelp.com/biz/tech3-auto-r...mance-san-jose
Old 07-09-2011, 05:54 PM
  #40
W203E35's Avatar
2006 C350 Sport 6MT
I just got this in the mail. Great price and very fast shipping. Can't wait to get them installed. Also can anyone guess why my front tire sidewalls keep cracking? Is it the messed up roads or is it because my tires were a little deflated??
Also Thanks Phi for this DIY!!!
Old 07-09-2011, 06:26 PM
  #41
phister's Avatar
06 C230 SS 6spd
Is it the inside or outside sidewall Karo? It could be due to deflated tires, it'll cause stress on the sidewalls. But it also depends on the tire brand as well. Some sidewalls are stiffer than others. Aren't you running 245 in the front?
Old 07-11-2011, 02:37 AM
  #42
W203E35's Avatar
2006 C350 Sport 6MT
Sorry for the late reply Phi, It's on the inside, before it was on the outside but I had them replaced because remember long time ago my front tire got worn out unevenly (bumpy). Today I noticed that my tire pressure was very low, 20psi. I pumped it 2 days ago to 50psi (recently I have been doing a lot of driving maybe that's why I loose air more frequently). I have a feeling maybe my front wheel looses a little air because I have a small bend on both wheels and when I run on low PSI it cracks the sidewalls. Drivers side looses air more quickly than passenger side. Rears are perfect!!
Old 07-11-2011, 08:30 AM
  #43
phister's Avatar
06 C230 SS 6spd
Your front wheels might be leaking air. What you can do is take them off an get a some soapy water and get a sponge and cover your wheel with the water. If you have a leak it'll bubble up where its at. But low pressure will cause the sidewalls to wear or crack.
Old 03-23-2013, 08:29 PM
  #44
precisionmike's Avatar
2003 C32
How do I know how much negative camber I have? I have read of some people saying they have "2.5 degrees". Is there a way to accurately measure? Phister- I am buying this kit based on your recommendation, keep the good advice coming. I rolled and pulled the fenders, came on great. Now on to fixing the camber. Mike
Old 03-23-2013, 11:45 PM
  #45
phister's Avatar
06 C230 SS 6spd
They take it to alignment shops and have it done. I personally have the SPC camber tool for my house. I thinks it's spc lol
Old 03-24-2013, 11:04 AM
  #46
2003 C32
Thanks for the response. I took a quick look on fleabay and found some DIY bubble level type camber tools. Iam a hardcore DIY guy, and will go this route. I just reinstalled a set of H&Rs with 1/2 a coil cut (prior owner). Car looks great, but way too much negative camber. With 15mm spacers, I am at +25 offset with 265's. After the roll/pull/grind- came out sick!, I have no rubbing and can just fit my pinky between the tire/fender. I will have to either keep pulling or reduce the spacer size after fixing the camber. Phister- I cannot imaging the tweaking you had to do on your car!
Old 03-24-2013, 12:38 PM
  #47
phister's Avatar
06 C230 SS 6spd
I can't even get a finger in my fender out back lol. I actually have to pull more or I'm going with 235/40/18 out back next.
Old 03-24-2013, 03:51 PM
  #48
2003 C32
Wow, I am guessing you rub? I actually relocated the bolt that holds the rear bumper trim on, moving it towards the rear about 2". Then I ground down the metal tab flush, all the way back to where the original hole was. No rubbing...yet. The camber correction will challenge that.
Old 03-25-2013, 02:21 AM
  #49
phister's Avatar
06 C230 SS 6spd
Yea don't have any bracket really left. I had to drill a new mount point for the bumper bolt. It only rubs on the highway on dips. About to lower the front more next week. My lip is already beat to crap so it'll eventually come off and I'll get my APR front splitter done.
Old 04-04-2013, 10:27 PM
  #50
2003 C32
Yet another shout out to Phister. I installed my new Ghostrider Camber kit using this DIY last night, and it went smooth . I did set the rods to 12" C to C. Still looks like a tad too much neg camber, but WAY better than it was. I have a camber gauge and will be checking tonight. The ride seems better, the car hooks a bit better and I will not eat up tires. Thanks again.
Quick Reply: DIY: Installing ghostrider's camber kit
