Lights electrical problems - wtf
Old Feb 13, 2011 | 01:48 AM
WhirlPool's Avatar
2005 C200 CDI
Hi everyone,
I have this weird problem for some time.
My Benz complains about problems with the lights almost every day.
The problem is that it's not consistent. Sometimes it's the Left Break Light, sometimes the Left Number Plate Light ... now it's the Right Mirror Turn Signal.
It can randomly pop each one of these for few hours and forget about it sometime later (usually after the car rests for a while turned off).
It drives me crazy ... I'm checking the bulbs just to see they're alright. I clean the contacts but it's not it .
Sounds familiar? I've searched and couldn't find anything solid.
Cheers,
Whirl
Old Feb 13, 2011 | 03:43 AM
samaritrey's Avatar
Super Moderator
THE C350
I sort of had this issue so i went and bought a replacement bulb for every exterior light and have not had the issue since.
Old Feb 13, 2011 | 03:55 AM
phister's Avatar
06 C230 SS 6spd
The mirror issue is kind of a common problem, you can either clean the inside of the mirror where all the wires are or alot of people just replace the socket which is pretty cheap. But check all the connections to see if they are fully connected, if any wires are exposed and touching the frame grounding them out.
Old Feb 13, 2011 | 04:07 AM
WhirlPool's Avatar
2005 C200 CDI
Thanks guys,
I guess I'll start with what you suggested:
1. Mirror issue - Clean and check everything is connected firmly
2. Replace all surrounding light bulbs - I have two sets of replacement already.
Will let you know how it goes in few days.
Old Feb 19, 2011 | 11:39 PM
WhirlPool's Avatar
2005 C200 CDI
OK, replaced most of the bulbs for the exterior lights.
Seems that the problem is gone for now ... well, at least no complaints from the Benz in the past few days.
Didn't check the mirror turning signal ... will do when / if the problem resurfaces.
Thanks for the tips guys.
Whirl
