stepper motor fuse
Old May 31, 2009 | 10:06 AM
quailou's Avatar
203 c320
stepper motor fuse
hi everyone
does anyone know which fuse is for the stepper motor (air con) in a W203 2001.
Its making a ticking noise and i just want to shut it up until i can get it fixed.
any help would be great.
thanks
Old May 31, 2009 | 12:17 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
These charts were courtesy of boohooramblers:
File Type: pdf
File Type: pdf
Old May 31, 2009 | 01:48 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by quailou
...which fuse is for the stepper motor (air con) in a W203 2001. Its making a ticking noise and i just want to shut it up until i can get it fixed. any help would be great.thanks
There is no fuse just for the stepper motors. All of the stepper motors are connected to one serial cable and that cable plugs into the climate control panel. You would have to disconnect/pull the fuse for the whole climate control to achieve what you want.....or, get all the air control flaps where you want them and pull the cable (requires removing center console panel to get to back of unit). That way you would still have AC and heat but lose the ability to direct it to vents other than where you set them before pulling the cable. Just make sure you don't have the Recirc activated if you choose to pull the cable. MB turns off recirc automatically after 15 minutes and I believe that's so you don't have a buildup in the cabin of the carbon monoxide you're exhaling.
Old Aug 21, 2009 | 01:39 AM
wallbearing's Avatar
C240
Angry AC Fan Fuse
Any idea where I can find the Air Conditioner Fax Fuse? My fan is not working. Thanks
Old Aug 21, 2009 | 07:11 AM
Glyn M Ruck's Avatar
Super Moderator
30, 41
https://mbworld.org/forums/c-class-w...2001-c240.html
Old Aug 21, 2009 | 06:53 PM
C240
Fuse Box with Fuse #30 0r #41
Originally Posted by Glyn M Ruck
I can only locate 3 areas where there are fuse box....one on the left engine compartment, second in the rear/trunk of the vehicle, and the third one is on the left of the drivers side dash board. Checked all the fuse and ok.
Could I be having problem with the blower motor, blower regulator, need to recharge freon, OR something else. Any idea will be appreciated.
Old Dec 29, 2009 | 07:18 PM
Davo's Avatar
W203 C180
Hey Boohooramblers, these pdfs can't be read by Adobe, they've been decoded by emailing. Any chance of a proper downloadable pdf so that I can find out what fuses protect what circuit in my 2001 C180?. Ta!
Old Dec 29, 2009 | 07:27 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
you might have a old version. I'm using the free adobe acrobat reader and it works fine.
Old Dec 30, 2009 | 05:28 AM
Super Moderator
+1 nothing wrong with pdf's
Old Feb 20, 2011 | 05:31 AM
pentech's Avatar
w203 c180
hi im using 2001 W203 Benz C180 right now,
yes i so glad i saw this forum and had copy of fuse chart. Anyway I have a concern maybe and i believe you can help me.
our main problem every time i close the door the wiper turns on, and also the Dome light doesn't work.
Hope you can help me out Hoping for reply soon or pls give me an email
teamvitessepentech@gmail.com
