DIY 05' C230 Komp - change vacuum pump due to oil leak...
Old 02-20-2011, 03:39 PM
nc1wynot's Avatar
2005 C230
Good Morning everyone,
I am new here but by the looks of some of these threads I've had some of the same issues...i.e. recalls, leaks, MAF, codes etc...
I just sent my 05 C230 Kompressor to the dealer for the 01-04 C230 recall (cam wire harness oil leak). They call me back a few hours later telling me about some oil leak on the vacuum pump. I did a bit of research and it seems its a popular leak with the C230.
I was wondering if anyone has done this repair themselves and what the steps were to completing it? Do you need to put the car on a lift to get to it? and should I just change out the pump or just the seals? When you buy the pump does it come with the seals?
I would greatly appreciate any information/pictures anyone could assist with. I am pretty mechanically inclined and have the tools required.
Thanks in advance for any help.
Steve
2005 C230 Kompressor
Old 08-18-2011, 01:49 PM
sadams's Avatar
2003 C230 A/T Coupe
vacuum pump
I found a link on this website to replace it with pics. if u still didn't find the info e-mail me at sadams@tellumat.com and I will send you the pdf. Then you can post it again.
Regards Shaheed
Old 07-06-2013, 12:52 PM
phonso912's Avatar
05 c230 kompressor
can you also send me that link, I also recently found out I also have a bad super charger do you have any ideas on this subject?
Quick Reply: DIY 05' C230 Komp - change vacuum pump due to oil leak...
