Help - Brake Assist Visit Workshop! BAS
Old Aug 25, 2011 | 07:02 PM
rave00fever's Avatar
2001 C320
Originally Posted by LILBENZ230
Do the brake lights work when this switch is out on your cars?
I don't have the brake light stuck on or off problem. I'm going to buy the part right now and put it on this weekend, hopefully.
Old Sep 2, 2011 | 06:04 PM
2001 C320
OK gents, finally it's the labor day weekend so I got some time to work on this. Following MW_ATL's steps, I like to provide additional pictures, and something I did differently on the hood release.
1. A quick look when the panel was first popped off
2. To disconnect the OBD connector
3. This is what I did differently from MW. With the hood release opened a bit, I removed the screw, and then massage/wiggle it out of the panel.
4. I have no idea what CANBus is, but I assume this is it:
5. Now you are looking at the cover just above the brake pedal
6. Push the foam aside and then OPEN SESAME
Old Sep 5, 2011 | 11:31 AM
efzauner's Avatar
2005 C240 2011 R350
Did you change the brake fluid? on my c240 2005 I did a brake job and replaced all the fluid with Lucas DOT4. Malfunction warning came on intermittently. I read up that the ABS needs special low viscosity fluid. So I flushed it out with MB OEM brake fluid and problem solved!
Old Aug 27, 2015 | 08:44 AM
pritpal.mudher's Avatar
mercedes benz w203
Hi,
Goo write up.
I had the same problem on my W203 C200K. I solved it by doing the following:
After removing the original part; I clean it and the contacts using electric cleaner.
Then I noticed the white plastic pink was sticking; So I pulled it forward and cleaned it so it is not stick anymore.
I assembled the part back in the car and hey presto; PROBLEM SOLVED!!!!
