Hids problem
Old Feb 24, 2011 | 11:20 PM
Kurupt's Avatar
02 c230k coupe
Hids problem
So i got my hid kit a couple of days ago.
I installed them and everything was working fine for a day or two. Then i got a message on my dash saying check front right headlight, low beam. I checked my headlights but they were working fine, nothing was wrong despite the error code.
Then last night, i go to turn on my car, my right HID is not working, but my left one is. Tonight, it started working and then after i came back to turn on the car again it wasn't working.
Does anyone know what could be the problem. Is it just a bad ballast or something.
Old Feb 24, 2011 | 11:25 PM
havoc_vulture's Avatar
'05 c230 Kompressor SS Mistress
do you have xenon's or halogen lights?
if you have halogen lights you probably need xenon=present setting done with STAR
what kit did you get?
Old Feb 24, 2011 | 11:35 PM
draz.amg's Avatar
'13 F10 535i / '05 W211 E55
+1
Are your xenon settings set to present? If not, then there's your problem.
Old Feb 25, 2011 | 03:29 AM
W203E35's Avatar
2006 C350 Sport 6MT
+3 definitely that's your problem.
I don't know if you can find someone with STAR or how much they charge but your other option would be to get error eliminators.
http://www.ddmtuning.com/Products/Er...minator-3-PAIR
Old Feb 25, 2011 | 08:52 AM
Kurupt's Avatar
02 c230k coupe
ohh i see, do you know why the left one is working but the right one isnt. Shouldn't they both not be working ??
ill order the elimnators today i guess
Old Feb 25, 2011 | 09:18 AM
phister's Avatar
06 C230 SS 6spd
If you dont want to buy the eliminators you can always do this DIY This what I did to my HID and I havent had a problem since my initial install.
https://mbworld.org/forums/e-class-w...es-models.html
Old Feb 25, 2011 | 10:46 AM
Kurupt's Avatar
02 c230k coupe
thanks for all the input guys
Although, could it be the ballast ? Because , i dont understand how one side works and one doesnt? if i needed the error code eliminators, shouldn't it be for both sides.
Old Feb 25, 2011 | 11:21 AM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Error cancellors dont work all that well. I bought them and still had to end up having the STAR coding done to change Xenon=Present.
Old Feb 25, 2011 | 12:07 PM
draz.amg's Avatar
Agreed. If you want it done right the first time with no problems, just change the xenon settings via STAR. Not sure how much the dealer charges but there's an option. Pretty sure a reputable Indy in your area can do the same.
Old Feb 25, 2011 | 01:36 PM
Kurupt's Avatar
02 c230k coupe
Yeah i understand that
but does anyone know if it could also be my ballast ? It seems like if it was the xenon = present problem that both of the headlights wouldn't work
Old Feb 25, 2011 | 01:40 PM
Xhale707's Avatar
C320 2002
My error cancellers work great
Old Feb 25, 2011 | 03:19 PM
Doubt it would be the ballast I put my HID's on for oneday and they did the same thing but my buddy tried another NEW ballast and it did the samething . So I say it the setting man.
Old Feb 25, 2011 | 03:30 PM
samaritrey's Avatar
Super Moderator
THE C350
why not switch them and find out
Old Feb 25, 2011 | 04:12 PM
W203E35's Avatar
2006 C350 Sport 6MT
