Alternator Price????
Is this a good Price for a new Alternator? The voltage regulator looks to be Bosh but I'm not sure if the Alternator actually is???? http://www.carpartswarehouse.com/par...00088_ON.html#
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Generally speaking for 2003-05 C230 they are Valeo. You can see the sticker (name) on the alternator looking at the back of it.
There has been reports by some who exchange their Valeo for a Bosch has caused problems, I know it does not make sense but it has been duly noted.
Why not just get your existing alternator rebuilt at an auto electric place, it probably be cheaper
why not have it rebuilt? If you live in any major metro city, there are plenty of alternator rebuilding shops.
If I do that though, dont I have to take it out myself? Then put it back in myself? Im pretty handy but that might be a little much....
anyone in the Sacramento area that can help out????
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
05 C230 Kompressor
05 C230 Kompressor
air intake crossover tube (no tools)
wideband silencer (reverse Torx set between 10/12mm)
sepentine belt (T-60 Torx to take off the tension, there should be a spot where you can put a bit next to the pulley)
lower engine cover (8 or 10mm screws)
disconnect neg battery cable (i think its a 10MM)
disconnect the electrical connector and cable from the back of alternator (i used an open end wrench)
remove the two upper alternator bolts from on top (again 12mm or 14mm reverse torx screws)
remove the two lower alternator bolts from the bottom (same as the step before)
(I removed the foward inner wheel liner for more access)
Remove the alternator through the top
Reverse to install
c200k
However, for those who have Valeo alternators, I highly advise checking the slip rings for gumming up. I cleaned mine off, along with the brushes, as they were being pushed into the housing and not coming down, and that fixed it. I was lucky, as I just finished a 1700km drive from southern France and right around the block from the house, the alternator stopped working. Some roads made stops and getting help in France impossible.
Wish that MB stayed away from that poorly made in France stuff. I am sure there are a few out there with Valeo rads that screwed up their auto transmission
c200k
I will agree. So far, their alternator is still doing ok by us, 18 months after cleaning the slip rings, but before I go back to Basque Country, I will examine them again and order a new one from the dealer, if necessary. It's an expensive regulator, even the no-name chinese ones are expensive and tough to verify fitment on. The prices are very close to dealer OEM. Wagner has it in their catalog, but won't ship to Germany, so forget it. At that point, I'm stuck with thinking about a replacement to the Bosch, since the regulator is a significant portion of its cost.
Mercedes staying away from cheap vendors? Valeo isn't cheap. Neither is Made in France. I can tell you that. Your alternative, if they're not making it in Germany, is the Bosch stuff made in destinations east of Germany and in China and at the most, assembled here in Germany. Any vendor can and has made absolute junk, like Bosch is considered many times to be factory seconds, even out of the auto factory. Their replacement track record is terrible, especially for Audi/VW. The problem does not exclusively lie with the vendor, but mostly with the manufacturer. They are specifying price and have their own engineers and accountants and lawyers negotiating, with knowledge of materials and how much of a warranty threshold they are supposed to theoretically handle. This aspect of Mercedes has been killing it- using the accountants to dictate everything down to cheaping out on seals that will fail and then devising contingency measures to even minimize the payout on the back end they've calculated in, such as the anti-freeze in the transmissions due to valeo radiators. To assign blame away from Mercedes is not only wrong, it's unrealistic. Mercedes is there every step of the way, forcing the hand of the vendor, and then the vendor takes the hit in their reputation, when all they did was manufacture a part to Mercedes' designs and specs.
What Mercedes does now is no different than what ruined GM- the beancounters controlled everything in engineering. Engineering might as well have been a sub-division of the accounting division. Mercedes also subsidizes its operation based on the costs of repairs and their frequency. This is why you get those 500% value parts that last 30-60mi. Perhaps not much different than other companies, but fairly high frequency enough that they're definitely turning profits there and even such incidents where they try (and it actually works) to make owners pay for off warranty repairs while they have a warranty.
c200k
I don't mind the valeo alternator- I mind the problems they have with their distribution network, even in Europe. So far, my valeo is doing ok. I posted on another benz forum about doing the long trip back to eastern germany from basque country, and then the alternator died around the block from the house. VERY lucky. I let it sit, then examined the VR- the slip rings and brushes were gummed with the insulating putty they used on the transistor. Lots of cleaning of both and they are good. The car only had about 50k miles at the time. The replacements are problematic; they now cost approximately what a rebuilt alternator costs, as the prices on the local rebuilt market dropped drastically since then. The independent shops are within 20% the price of dealer, which is likely now about 6-700 euros. The local rebuilds are almost always going to be Bosch. At the dealer and independents, they only sell Bosch.
I contacted Valeo direct in France, who keep insisting that I have to go through a dealer (when I wanted an independent). Valeo confirmed stock, but not a single independent was able to order it, as there was a breakdown in valeo's distribution network. So the part is available, but not orderable through retail, valeo can't figure this out and how to make anyone order it, so there you go. You have people like me that bash them because their business is so big and so rigid, it can't even get a part to a customer. I have little doubt that the alternator itself is better built than the Bosch, likely reflected in the price.
What exactly are the slip rings and how did you fix this. If I remove the VR, then what?
c200k
I guess some would call it the "commutator". It was quite easy, but I advise doing the job with the battery disconnected for obvious reasons. I simply blindly removed the regulator from underneath with a combo of of ratchets and short drivers. Not hard at all.
I pulled the VR straight back (was under the car, naturally), but it was a bit stuck due to the putty they use. When it was removed, it was clear there was not only a THICK layer of this putty on the rings, but also they were preventing free movement of the brushes in and out, which was likely responsible for an occasional warning light condition on the dash directly after cold weather starting, which went away after a few seconds. There were also occasional moments when the engine would jerk on shifts and momentarily, I would see the dash light up. No doubt, this was also affecting charging capacity.
I cleaned the rings basically with little finesse. Electrical cleaner or brake cleaner and you must be able to manually turn the engine slightly because cleaning can't be done 360 degrees. I'm not recalling, but a ratchet and maybe a 27mm socket did the trick to turn the engine. You can also remove the belt and spin the alternator, but I didn't have the conditions to do that here. The VR has to be bathed in cleaner for a while. Work the brushes back and forth, spray, drain, over and over, work the brushes until free. I also used a 10 second rub on the rings with a tiny bit of superfine sandpaper and electrical cleaner. Also remove the brush hood (you will know what I'm talking about when you see it). In my case, some of the material was packed inside. In fact, I might have actually pulled the hood first before pulling the regulator and saw the issues, but don't quote me on it. You have to pull the regulator to know for sure.
c200k
That looks like the one I pulled from my car, yes. The numbers, direct from someone at Valeo France are as follows:
"Hallo,
der Regler für den Generator SG12B021 heißt 593392 und ist über den freien
Teilehandel zu bestellen 4-5 Wochen Lieferzeit
Mercedes Ersatzteilnummer A0031541706"
"Hallo,
c200k
Here is an aftermarket equivalent I found in Germany, with a different appearance, but satisfies the interchanges:
http://www.atk-autoteile.com/xtcomme...103-R--VW.html
Quite well priced. Another ebay company was selling ones that looked closer to the one we have for 13 euros, but they are long gone. The rest are still pretty expensive.
If you have a 3.0 L then it is http://www.americanenginesco.com/ser...ENZ-E-C/Detail
Or it could be this one if you have the M271 engine http://www.americanenginesco.com/ser...RIES-Z4/Detail
Here is a list of various VR http://www.americanenginesco.com/ser...ors/Categories
c200k
It has to be matched by interchange. Some look similar, but have such things as extra terminals or the connector hood is half shrouded, or taller or shorter. I think some have a different B terminal, too. For my particular model, in the post somewhere above, I posted the alternator number for my car, then the corresponding Valeo number for the regulator, and the Mercedes replacement number for it. That's how you find them. You have to get the alternator number from the silver sticker underneath and then go from there.
It is not advised to go by looks.
