spacer question
Old Feb 27, 2011 | 10:06 PM
03c320's Avatar
03 c320
spacer question
i am planning on getting a set of 19x8 wheels with a 32mm offset. and was wondering wat kinda spacers i would need to get so that the wheel would be kinda flush with the fender on my 03 c320.thnx for all the help
Old Feb 27, 2011 | 11:08 PM
bheng's Avatar
2003 CLK 320
trial and error kind of thing.
you can always put the wheels in and measure the distance between the wheel well gap and fender. thats one way to figure it out for sure.
Old Feb 28, 2011 | 12:44 AM
phister's Avatar
06 C230 SS 6spd
5mm spacers will be good enough. around +25 offset will make it flush. I have +20 infront and +25 in rear, I had to stretch the front tires some because the +20 is pushing the wheels out a little too much, but I had to do this because the rivets on my wheels where hitting my calipers.
Old Feb 28, 2011 | 03:06 AM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
i have a 19x8 +32 up front, im running a 20mm spacer to bring it down to a +12. Its pretty flush, but could probably go a couple more mm to make it perfect.
Phister: are yours 8 or 8.5?
Old Feb 28, 2011 | 03:14 AM
phister's Avatar
06 C230 SS 6spd
i'm running 17x8.5 +30mm then added 10mm spacers upfront to make it +20mm. Had to stretch the fronts a bit so it wouldnt hit the fender I'll take pics in the morning from the front view and from up top. it almost sticks out too much. I always forget you're running 19x8 in the fronts. I'm trying to go lower, so my Teins are for sale, want to get the H&R c/o because they go about 0.8" lower than the teins. If I dont sell them I might just take one of the perches off and see how low the front will go
Old Feb 28, 2011 | 05:24 PM
03c320's Avatar
03 c320
ok thanks guys.because i say in the pic thread that some people say they have +35 all around and no spacers and they are pretty close but i was readin in some older threads and they seem to show a spacer to get them pretty close.
Old Mar 1, 2011 | 01:28 AM
phister's Avatar
06 C230 SS 6spd
it all depends on the wheel design and how the spokes are... some curve outward to accomidate the larger calipers and some are straight spoke, and some are concaved so its all based on wheel design. You would think mine with a +30 all around would've worked but I had to take into consideration the rivets of the wheels so I had to get 10mm spacers for the front. I did 5mm in the back to make it flush, 10mm in the rear and my tires were right against the fender.
