Weird vibration from starting engine
Old Mar 2, 2011 | 09:20 PM
aigooalex's Avatar
2007 C230 Sport
I started my car up and for some reason, i felt more vibration than it normally did... something wrong or...am i just trippin' out?
Old Mar 3, 2011 | 07:49 AM
ericgoh's Avatar
2003 Mercedes C240, 2009 Audi Q5
Do you mean the engine is idling rough? Or are you talking about the actual starting? How many miles on the engine, plugs, etc?
Old Mar 3, 2011 | 11:02 AM
billbillw's Avatar
2001 E55 AMG (sold)
Could be a random thing or the start of a problem. Just keep an eye on it. If you have any serious problems, you should get a check engine light.
Old Mar 4, 2011 | 12:58 AM
04mbc230's Avatar
2006 C230 Sedan
Check to see if the enginee oil is at level. I have that problem and notice that the engine oil was getting lowed. I had at least 2 quart and now the vibration is minimize.
Old Mar 4, 2011 | 03:29 PM
aigooalex's Avatar
2007 C230 Sport
I'm the second owner of this vehicle. I have no records of what the 1st owner did but from when i got the car at 36,000 miles i have now 53,000 and always have done regular oil changes from 3k-4k intervals.
I am way passed by service B but wasn't too sure if it was needed.
When would i need to change the spark plugs / engine belt / tranny fluid?
But yeah... it just started up really rough... just more than usual =/
Old Mar 4, 2011 | 03:31 PM
samaritrey's Avatar
Super Moderator
THE C350
Transmission fluid now so it lasts a very long time
Spark plugs i think are 5 or 7 years or 100k
don't know serpentine belt but check it for cracks i would say when you do spark plugs if it is in good condition.
Old Mar 4, 2011 | 04:54 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
With the fleece filter you are changing the oil every 3-4k miles? You're throwing money away big time on that. Best do the oil services less often and tranny ones more.
Old Mar 4, 2011 | 05:05 PM
amanonfire's Avatar
W203
Plugs. Plugs are a 60K miles or 100K kms item.
Is the idle rough only at startup after sitting a long time (ie overnight)? Does the rough idle go away after driving for a little bit?
If so: Plugs. Your plugs are old and need changing. When the engine is cold they don't work well enough and you get misfires, thus the rough idle. Once the engine is warm the plugs work better.
Old Mar 4, 2011 | 05:42 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
RTM!!!!! If you don't have one, download here.
Spark plugs on the M272 W203 which the OP has, is 91,000 miles or 5 years. Oil changes are 13K miles or 1 year. Transmission service is every 39,000 miles (non-time dependent). Serpentine belt has no specified change interval, it is to be checked every Service B. Mine has never been changed, and I am at 85K miles, and it is still in good condition.
As for the vibration, check engine/transmission mounts, run a bottle of Techron for a tank, try different fuel, etc.
