Climatronic Control Question
I agree that the buttons sometimes 'stick' and there is a trick to hit the buttons without getting stuck. This does require you to not allow any passangers to touch the controls.
I paid only $75 for my unit, I know its not worth $200+ even if it looks better.
For me, I usually leave it on one temp all day long, so all I hit is 'auto' or turn the speed to 'off'. If your the type that changes the temp all the time, stay away, its not worth it for the look.
Erik
does it require to have some work on DAS ?
greetingz,
no...it only requires some luck with your car...either the car excepts the controls or doesn't...(meaning that you only get hot air...cold air...only air through the lower vents...)
greetingz,
Erik
What's the 'trick'? I've had one button stick about two years ago and I lightly tapped it to release it.
"I agree that the buttons sometimes 'stick' and there is a trick to hit the buttons without getting stuck."
Erik
did you get the same part # for your car the second time and it worked. if thats the case, i think it has something to do with the emmission #'s on it. did you notice them.....they're another set of #'s above the part #.
tifosiv122
Erik
