Emergancy brake help!
07 c230
i was changin my brakes and got the first one done. the one on the drivers side tho has become a problem. the two calipers are stuck. theres a few millimeters of room to work with but they wont butdge past it. need help.
Your message is not clear...
Are you trying to change the pads on parking brake/emergency brake?
When you say calipers, are you referring to the caliper on the brake rotor? If so, after removing the pin, pull out the brake pads, then use a C-clamp and push the piston in the caliper.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
The Emergency brakes are drum & shoe mounted inside the rear rotor hats ???
