Something I found..
Old Mar 19, 2011 | 03:59 PM
Norwichdelta06's Avatar
2007 c230
Something I found..
Im planning on doing my retrofit with depo projectors. I found this website/link that may help others as well. It is a step by step instruction for a RSX retrofit.
http://www.retro-solutions.com/05TSXRSXINSTALL.pdf
Old Mar 20, 2011 | 01:07 AM
Silver C's Avatar
C240
Let us know how It turns out.. Im considering of switching my headlamp to the projector type, but may consider retrofitting.
I am also aware that depo projectors may tend to have a less focused light, womder if its true..
Old Mar 20, 2011 | 02:01 AM
Xhale707's Avatar
C320 2002
That looks like so much work.. Good luck getting the dust out once you open it up.
Old Mar 20, 2011 | 04:19 AM
fookoo303's Avatar
2003 c240
Be aware that when putting into the oven, you may need to go higher temperatures. When i took apart my aftermarket projectors, the sealant wouldn't melt under 250 degrees. If your plastic on the headlights start to leave impressions while prying apart, then you need to increase the temperature. It should come apart without damaging the housing.
Old Mar 20, 2011 | 01:38 PM
2007 c230
this is why i'm going to buy the depos and do a retrofit...
https://mbworld.org/forums/c-class-w...ht-cutoff.html
From my understanding and searching from this forum the DEPO projectors are suppose to be exact repliaces of the E55. The Depo lenses themselves are 2.75 inches. and the E55's are 3 inches. The TSX's are 2.5
http://www.retrosolutionsllc.com/ser...etrofit/Detail
This website has helped me a lot!. But i'm definitely going to EBAY when buying the parts!
Old Mar 20, 2011 | 05:17 PM
samaritrey's Avatar
Super Moderator
THE C350
also don't touch the element like i did :****(
