W203 Secondary air pump relay
Hi, can someone point me which one is the relay for the secondary air pump? A photo or map
would be appreciated. C200 Kompressor M111.955 engine
I'm having the same problem with my m272, smog pump not actuating bank 1 and 2.....basically smog pump doesn't run. I was told by an indy i would need to replace the front sam as the smog pump relay is built into it, im still doing research but its not looking good.
Yea it does not sound right. I can move the flap with hands.And it turns. Do you know which wires i have to connect to the 12V in which order to see is it really the relay?
not sure what u mean by flap but i tested mine by switching it with another member. My pump worked on his car, his didn't work on my car i also switched my check valve but no luck with that either. u could test the pump manually i guess by removing it and hooking it up to a 12v with some spare wire....i would be careful not to burn the pump as i'm sure u probably have the same problem as me.
2007 C280 4matic Avantgarde
https://mbworld.org/forums/c-class-w...0-code-sc.html
Check att: pdf post 13 from Glyn, looks like that air pump relay is for 112, 113 and 271 engines so 111 doesn't have one.
Super Moderator
From Facebook ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I wish this rain would stop. I have a lot on my plate today. Pick up springs, install springs and shocks, paint calipers, get a new tire, brake fluid flush, brake job, mount tires and paint Euro impact strips!!!! I hope I can make it just in time for the MBJunkies meet.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Here is front sam wiring diagram if that can help somehow.
BTW why don't you update your profile with year and model of car?
