CEL P2767 Transmission Problem
I tried to search for this topic but nothing came up. Does anyone know if this is a major problem and needs to get fix right away? Plus the cost!?
I assume you are out of warranty? This will not be cheap to fix, as there is several hours of disassembly of the transmission to get to the bad parts.
Since this is a known manufacturing defect, I would print the DTB, and take it to your local MB dealer and see if they will take care of it under warranty as a goodwill gesture. Either way, I recommend getting this taken care of ASAP.
