Oil analysis results
Old Mar 26, 2011 | 07:22 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This is my latest oil analysis. This oil was ran in my 2005 C230K with a Mann paper filter from 81,400 miles to 94,800 miles without a drop being added to it during that time. The air filter was replaced at the same time this sample was taken, so the air filter element had 41,000 - 54,000 miles of use when this oil was in the car.
I'll not be extending the interval past 13,000 for the record. I do it when the computer says so.
Old Mar 26, 2011 | 07:30 AM
HitUpOlas's Avatar
2005 C230 6spd
How much does this cost with shipping?
Old Mar 26, 2011 | 09:00 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
$25. http://www.blackstone-labs.com/tests-price-list.php
Old Mar 26, 2011 | 09:14 AM
johnand's Avatar
Super Moderator
Matt,
Considering the mileage on your car AND the paper filter, those are pretty good results. Though, I always cringe at the iron numbers from M1.
I thought you did a lot of long highway trips normally, but did you do a bunch of short trips this time? I am just thinking about the fuel dilution.
What always has puzzled me, is in your car the M1 doesn't seem to shear like it does in every analysis I have seen. Out of the bottle M1 has a viscosity of 13.33. I suspect it is shearing in your engine, but then thickening again as it oxidizes. I wish Blackstone included TBN in the standard test, as that would help solve that mystery. That is why I prefer Oil Analyzers, because they include TBN for the same $25.
Hope Glyn will chime in here. I would like to see him comment on the Manganese numbers that creeped up on this report. The virgin oil has 0, so this must be a wear particle.
M1 0W-40 is definitely an excellent oil, just wish it could control iron a little better. I will be sending in my analysis of Pentosin next week. I am hoping it performs as well as M1, but with a reduction in iron.
Old Mar 26, 2011 | 05:24 PM
LILBENZ230's Avatar
I did do shorter trips during that period. I plan to have it analyzed every other change, so again at 120,000 or so and I'll do the TBN.
But I think this shows that there is nothing wrong with the 13000 mile interval. Maybe if you live in very dusty areas or something, but if you live here in GA, spend a lot of time on the road, and are changing your oil every 5k miles you are throwing money away.
I drove 800 miles last night to visit Drew in Florida.. I'm at 107k and it's time for another change.
Old Mar 26, 2011 | 07:01 PM
contact148's Avatar
2003 c240 4matic wagon
seems to be alot of guys with slightly higher then normal fuel results
question do you idle the car alot??? the short trips might be why but water was ok so you got it hot enough
everything else looks ok
Old Mar 26, 2011 | 08:38 PM
Glyn M Ruck's Avatar
Super Moderator
Good Report.
Sources of Manganese:
Manganese (Mn) can show up in the following components of an engine as:
Minor element:
Wrist pin & bushing
Piston rings-various
Blowers
Trace element:
Gears-misc.
Crank shaft
Cam shaft
Cam follower
Valve train & valves
Cylinder liner (unlikely with Benz Alusil)
Roller/ball bearings-various
Minor element- medium concentration range relative to a Major element. Appx. 20-50% of a major element
Trace element- very low concentration relative to Major & Minor elements. May no show up in a concentration high enough to register above instrument detection limits.
I'm of the opinion that the majority of the Manganese found in Matt's sample is from the fuel. Afton Chemical (formally Ethyl Corp) supply the US & Canadian fuel industry with Octane boosters containing Mn.
Old Mar 26, 2011 | 08:49 PM
LILBENZ230's Avatar
No the car does not idle a lot. This was a while back for me so I can't recall that much of what went on.. It's a small amount and none was present in the previous sample.
Old Mar 26, 2011 | 09:23 PM
Super Moderator
Yeah Matt - I'm not talking from your very slight fuel dilution - But from fuel in general that the engine sees. In the days of leaded fuels there was always plenty of lead in oil samples with zero dilution. Elements of fuel additives get into the sump.
Old Mar 27, 2011 | 12:03 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
I'm glad the news is so good! I never did get the email.
EDIT: I take that back. I got it, but it didn't come to my phone... hmm.
Old Mar 27, 2011 | 04:53 AM
LILBENZ230's Avatar
And Drew I am glad you got to drive my car and that you understand the somewhat special appeal of the 2005s.
