Highway wander, any ideas?
I have an 03 C230K with 138,000 miles. It used to be rock solid on the highway, with great center feel. The car stayed where you aimed it. Starting around 100,000 miles it began to wander a little, requiring constant steering correction. I was run of the road last summer (a story for another time), and went over a curb. Messed up the control arm. I decided to overhaul the front end. Upper and lower control arms were replaced along with tie rod ends and a complete brake job.
The front end is back to normal, feels solid over bumps, no vibration. But, the car still wanders on the highway. Any ideas as to what may be causing this?
Well perhaps you need a realignment of your wheels my friend, did you do that when you did the front end? There may also be tire or rim issues when you had your misfortune, so did you change or inspect damages on them?
After the front end was redone, I had the car aligned. It drives straight. I had to replace my summer tires after the accident. I have snow tires on their own rims. I have this problem with both the snow and summer tires. It's not terrible, but a little irritating.
John, if the car drives straight after itwas aligned, and wanders off after you change your wheels back and forth, well I think it is highly recommended that you realign them everytime you change your wheels.. Since there must be some difference between the two sets you have and it affects the alignment slightly everytime you drive around. Hence when you switch back you still feel the difference..
2003 C230K Coupe Orion Blue
Check the tie rods. Mine went at 100000km. One of my wheels was flopping around on the highway because of this. I thought it was a crappy alignment job until I put my car on a hoist and realized you could rotate the wheel (without the steering wheel also moving) with your bare hands. This was causing my car to "wander" as well, so I'm almost willing to bet this is the problem.
By the way, there is no vibration at speed. Everything feels great except for the on center steering.
I have the same problem right now and on twisting both outer tie rod ends, they both moved with barely any effort and my steering wheel shakes while braking at all speeds.
I thought I'd bump this thread because I have a similar issue.
My cars goes slightly to the left. If I put a few extra PSI into the left tire it drives better. Tire guy says the car front doesnt have any adjustable cambers or casters (not sure which term to us sorry).
What's the best way to align the wheels on a w203 then? Just keep that extra little bit of PSI in the front left tire?
Super Moderator
Tyre guy is talking crap. Fit the fluted 3 way camber and castor bolts. See the whole description in the DIY threads in the stickies.
Then set your castor one degree more positive on the LHS than the RHS. Typically 10.6 degrees & 9.6 degrees. Your car will then not pull with the camber of the road.
The reverse applies to LHD cars.
Super Moderator
Your car on every single wheel is adjustable to a certain level. So if your tire workshop says its not possible then it means he's not competent enough sorry.
Ideally your car should run straight at where you aim it at on a flat road. Adding Psi is a temporary solution and not the best.
I would have your car checked forany faults on the tierods or bushings and or even your rims.
Super Moderator
I have edited the post above with more detail.
This pulling problem on Benz is common - not only W203. MBSA has drummed the castor settings into every tyre shop in SA. It fixes the problem every time unless your front tyres have worn badly.
Front tyre ware looks ok to me thank goodness.
Just one question; so to do the adjustment, do you need to install the 3 way camber?
My tyre guy isn't doing out of spite I believe, he may not be as competent as Mercedes Benz as he is other makes. Its a Jaguar, Rover, Austin Martin etc dealership.
2007 W204 220CDI Classic Sedan
Is this information relevant to the W204?
JC
the tyre chap is a nice guy, he admitted he is not sure how to install these on a Mercedes and recommends I go to a specialist. But other then this, he's a nice guy and he organised me the two free tyres from the sales rep.
Super Moderator
I will get this done next service. But at the moment, its ok if I keep a slightly more pressure amount in my left tyre. Even if I keep 'em both the same PSI, it only drifts slightly.
You need two bolts to adjust castor & another 2 to adjust camber.
Benz is just cheap. They install a standard bolt that only fits the centre position in the bushes. In fairness the "chassis" on these cars is strong.
Funny thing was I asked to chap to do one job (different to my current tyre guy) and he accidental did the castors. He felt really bad and instead of taking them out, he just gave them to me for his wholesale price and charged me half the labour.
