Middle of a DIY and need help :(
Old Apr 20, 2011 | 01:46 PM
CanadianSteel's Avatar
2006 C230 6 speed
I'm replacing the 3rd brake light on my 06 C230. Thought it would be an easy DIY but i have a problem. I can't get the trunk trim off. I took out all the fasteners but the plastic part with the handle will not come off. I have inc some pics, Is there something i'm missing or forgetting to do here.
Attached Thumbnails Middle of a DIY and need help :(-002.jpg   Middle of a DIY and need help :(-003.jpg   Middle of a DIY and need help :(-004.jpg   Middle of a DIY and need help :(-001.jpg
Old Apr 20, 2011 | 02:02 PM
infected's Avatar
2007 ML500
Look inside the handle, there should be 2 tabs that can be pried out gently with a flathead. That will release the entire assembly.
Old Apr 20, 2011 | 02:05 PM
2006 C230 6 speed
Just the plastic tab?Yes i see them, I'll give it a try.
Old Apr 20, 2011 | 02:19 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Don't forget to wear your hardhat.
Old Apr 20, 2011 | 02:23 PM
2006 C230 6 speed
Lmfao, Hard hat check!!
Ok so i got the handle off, now there seems to be 2 rubber knobs preventing me from getting it off. Pics inc.
Thanks btw, good to have a place to turn to when your in trouble DIY wise
Attached Thumbnails Middle of a DIY and need help :(-006.jpg   Middle of a DIY and need help :(-007.jpg
Old Apr 20, 2011 | 02:25 PM
WaveyKat's Avatar
Something Slow
look thru this thread :https://mbworld.org/forums/c-class-w...e-light-2.html
Old Apr 20, 2011 | 02:34 PM
2006 C230 6 speed
Thanks for the link, but my problem remains. Just can't get the carpet backing off.
Old Apr 20, 2011 | 02:43 PM
W203E35's Avatar
2006 C350 Sport 6MT
I folded mine off. I didn't take the rubber stoppers off.
Old Apr 20, 2011 | 03:05 PM
2006 C230 6 speed
you mean you left the carpet on? Just folded it down, or folded it down and then took it off?
Old Apr 20, 2011 | 03:18 PM
W203E35's Avatar
2006 C350 Sport 6MT
Like so
Old Apr 20, 2011 | 03:22 PM
phister's Avatar
06 C230 SS 6spd
If you look on the right side if the handle there is a tab. Get a flat head and push it outwards. It should release the plastic handle. Make sure you've removed all the tabs holding the carpet on, think it's like 8 or so push tabs lined throughout the carpet, just use a flathead and pull the inner tab up then pull the whole tab out. You wont have to remove the two knobs, the carpet slides over them.
Old Apr 20, 2011 | 03:48 PM
eesjunin's Avatar
Nowhere ...Fast
if she has a carpet in her trunk...then you got a serious problem!
Old Apr 20, 2011 | 06:06 PM
2006 C230 6 speed
Thanks all, project done!! All that was needed was a little muscle to pull it out. It had to be pulled over the two handles on top of the trunk. The clips holding the lamp in place were very hard to get to and even harder to put back. but it was well worth it
Old Apr 21, 2011 | 01:46 AM
samaritrey's Avatar
Super Moderator
THE C350
