Electrical feedback noise through radio speakers
Old May 1, 2011 | 12:50 AM
AL Z's Avatar
Hello,
I have a 2005 C230 sedan.
I started to get ignition noise feed back through my radio speakers. When the ignition is in the acc or on position. You can hear the ignition noise through the speakers constantly. It also makes it louder when I step on the brakes. Is there some type of noise suppressor that may have failed on the car and if so, where is it located. Any help would be appreciated.
I stop using the radio because of the annoying feedback noise.
Thanks in advance,
AL Z
Old May 1, 2011 | 11:28 AM
AL Z's Avatar
Anyone have any ideas?
Old May 1, 2011 | 11:31 AM
vdemon311's Avatar
2006 c230
Sounds like you might have a loose wire somewhere ... or possibly a bad connection behind the head unit?
Old May 1, 2011 | 11:49 AM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Do you have HID's?
Old May 1, 2011 | 07:19 PM
AL Z's Avatar
Thanks for the responses.
I did install some HID's about a week ago. I did think that may have been the issue, but I was able to trace it down to the sub woofer amp. I think it may have gone bad. when I disconnected the input rca leads to the amp, the noise went away. left the leads disconnected until I can remove the amp to get it tested.
Thanks again,
AL Z
Old May 2, 2011 | 01:21 PM
hcoronado's Avatar
2021 GLC300 4Matic
sound more like a bad ground either at the HU or at the amp.
Old May 2, 2011 | 01:28 PM
phister's Avatar
06 C230 SS 6spd
do you have your power wires running down one side of the car and the rca's running down the other? If not that could be the issue, you're suppose to keep the rca and power wire from to the amps as far apart as possible.
