Getting coilovers for a wagon?
Old May 10, 2011 | 03:30 PM
AMG__Dom's Avatar
W202 C55 (5.4 swapped C43)
Hey guys had a quick questions will coilovers for a W203 sedan fit on a W203 wagon? I know that it says excluding on most sites but I dont udnerstand why other than possibly needing a stiffer spring rate in the rear?
Old May 11, 2011 | 02:27 AM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Yes, should fit w/o any problems. I installed a H&R Cup Kit on my wagon that was also listed for all W203 except wagon. You are also correct that the rear did sag a little (I corrected by changing the rear springs).
Also, hit up glocati, he has coilovers on his wagon. Or hang on, he'll probably chime in here soon.
Old May 11, 2011 | 12:00 PM
I_C_Class's Avatar
W204 C350 4matic Coupe, W203 C320 4matic, W212 E550 4matic
Is your wagon 4Matic?
Old May 11, 2011 | 01:00 PM
AMG__Dom's Avatar
Thanks I messaged him and he said the same thing, and no the wagon is not 4matic.
Any recomendations on coilovers? Was thinking about getting BC coilovers dont want to get the H&R's as there isnt enough adjustability and they dont go low enough
Old May 11, 2011 | 11:49 PM
hanknum's Avatar
Oh, don't forget to post pix of your wagon on the W203 wagon thread.
Old May 12, 2011 | 12:09 AM
Silver C's Avatar
C240
Yeah, wagon's rear does sag a little more due to the extra weight on it. So you'd probably have to adjust it accordingly if you're getting them coilovers. I personally think the coilovers are very expensive.
Old May 12, 2011 | 12:22 AM
AMG__Dom's Avatar
Will do haha
I see and yeah I know it is going to cost a bit gonna call the company tomorrow and see if I can order them with a stiffer spring rate in the back
Old May 12, 2011 | 12:50 PM
glocati's Avatar
2016 GLE 350
Yes, Henry installed sedan specific kit in his wagon with no fitment issues. So, with this in mind we surmise that it is a spring rate issue ( not fitment) in the rear, as the butt end of the wagon is heavier than sedan.
The only outfit I found that made coilovers specific to the w203 wagon is H&R. They will run about a grand $$.
As an FYI, the H&Rs do go pretty low. My wagon is pretty low and I have
about 7-8 thread lefts left in adjustment, so it could go lower. The fronts are not that hard to adjust, you must remove the front wheel to do it, however. The rears are kind of a b#tch.
Greg
Old May 12, 2011 | 08:32 PM
AMG__Dom's Avatar
I see how do you go about adjusting the rears? Ive heard you have to drop the control arm to get the adjuster?
I spoke to BC today they said that once im ready to order I can get custom spring rates front and rear so im gonna stiffen up the rear spring for sure
