Morimoto H1 RETROFIT
the back lighing issue can be solved with high temp aluminum tape but to be honest it will barely fit in there. There is someone on this forum who did it? Its a recent post. The picure I posted on this Thread is a morimoto compared to a FX projector
well these were reallly easy to do. the only thing I had to dremel was the two plastic tabs on the back of each headlamp. You'll see what i'm talking about once you try to get the adapter plate on
The Centric Hub rings from TRS are awesome!! But do not rely on them staying put. Use the Centric hub rings with black RTV silicone and that thing is not going anywhere!
Will that Morimoto retrofit kit you posted work with these? Is that install that difficult?
I've taken apart Subaru STi headlights, but never these. (Kind of scared to with how much they cost!).
Whatta you think?
Could you write up a how-to for us? I'm very intrigued...
Las Vegas, NV. How about you?
http://www.theretrofitsource.com/pro...products_id=72
I was going to do that this weekend actually! And i believe the lightoutput would be better also because with the E55 shrouds it is letting light out behind the shdrouds and the gattling covers the entire projector. Because when i was along side a wall I do see a little bit of scattered light with th eE55
