Newer steering wheels work with older models?
Old May 18, 2011 | 05:36 AM
sihota69's Avatar
W203 White C Class
stock steering wheel for 02 w203 is ugly lookin to get a new one like this...not sure if itll work but they both have the same functions.. thanks
Attached Thumbnails Newer steering wheels work with older models?-38294_422322839472_518134472_4596435_2466047_n.jpg
Old May 18, 2011 | 05:45 AM
sihota69's Avatar
W203 White C Class
same goes for the instrument cluster, will a newer one work
Old May 18, 2011 | 05:54 AM
BigBodyBenzC240's Avatar
...a panty dropper...
Next time try and use the search function, you will find everything you need.
W203 Facelift
In regards to the steering wheel it would be cheaper if you just pruchased a newer wheel design and use your stock airbag since the one you listed will not be cheap and I dont believe its plug and play anyways. Check these ones out.
Steering Wheel
Good luck.
