Group Buy: C32 Brake Upgrade
As the company that first brought you the C32 brake upgrade, we are please to also offer the most competitive pricing. We have lowered our retail price to $595.
Even better, if 10 (or more) people come together to purchase the brake upgrade, I will lower the price to $549. This should give everyone the opportunity to have equal stopping power as the C32!
Thanks,
Ben
Thanks,
Ben
The C32 /03 CLK55brake upgrade consists of the front rotors, calipers, pads, and pad sensors. Doing this will give you the exact front brakes as the C32/03 CLK55.
Thanks,
Ben
Thanks,
Ben
Location: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Thanks,
Ben
Thanks,
Ben
Originally posted by Xeon
mach...i will be back in singapore for 3 mths...can i get it when i come back? or is it too late??
The spare would have to be at least 17" (and probably need a spacer). There is no point in doing the rears. The majority of your braking is done in the front of the car, and the C32 rear brakes are nothing to brag about.
For the $549 pricing, we will need 10+ orders. At $595 I can take the order now. If you would like to get in on the $549 pricing, please email ben@evosport.com with your full name, email address, and phone number. I will then contact you for billing information.
Thanks,
Ben
Thanks,
Ben
2002 C240 Classic
ben, is there any way you can make the brake "package" with brembo cross-drilled directional rotors as opposed to the brembo "AMG" non-directional rotors?
Yes the 209 55 brakes will fit the CLK209 55. You would have to change the entire brakes, not just the rotors, as they are different sizes and would not line up properly.
Thanks,
Ben
i have a question regarding the amg brakes.
if you add a better/bigger or more powerful caliper to do the stopping duties but do not change the tire on the car, then in reality you have gained nothing. the tire does the stopping, not the caliper. the tire is what offers the resistance to the road, not the caliper. so my question is why would someone pay this money to gain nothing more than a caliper with the amg logo on it?
also a car with abs will only apply so much pressure and then will release it upon the onset of lockup. the lockup is caused by the tire losing traction on the road surface, so what is to be gained by this upgrade?
this is not meant to start a flame war, this is a valid question i would like answered. actualy i have answered it im just curious as to the views from the other side.
'01 C320 SS
Will I be able to use my stock wheels? Every so often [when my wife dents a wheel], I put them on. Is it a do it yourself [Kwik] job?
'01 C320 SS
2. It looks better for those who've done a +2 or +3 wheel upgrade.
MBWorld Founder
ones too fast according to CHP!
That actually is not 100% true. Pretty close. However, a caliper's material and design can help to dissapaite heat, thereby reducing fade. The less heat, the more fade-resistent. Calipers that have more pistons and more surface area and have a more efficient design do resist heat more then cast one piece one piston calipers.
You should see some of the race Brembo calipers we use! WOW.
Brad
Brad
Thanks,
Ben
MBWorld Founder
IF the tires are the limiting factor you are 100% right. However, that is NOT the case here. Any good street tire has FAR more grip then the factory brakes can utilize. Look at SPEED World Challenge. Touring is forced to run on street Toyo TA1's and you will still see EVERY car with Brembo, AP or StopTech. Are you telling me that this is for looks only? Nope, this is for 1) fade resistence, 2) better modulation, 3) more consistent stopping, 4) shorter stopping.
Also, as to the ABS issue, you can get shorter stops with a bigger kit, again because the tires are not the limiting factor. Yes, the ABS will release at the onset of lock-up. However, with a bigger kit you will have more surface area of contact (rotor to pad) which will bring the wheels/tires closer that point of onset (shorter distance) and apply greater force, slowing that spinning mass down much sooner.
Your thoughts on this are pretty good, you are just assuming the wrong factor as the limiting one.
Brad
