Transmition
Old May 27, 2011 | 03:49 AM
khalilnasser's Avatar
c240
Exclamation Transmition
I have a C240 2002 , i found a leak near the radiator i fx it and added fluid to the tranmition , after that i started to monitor the transmition sometime i feel the car shifting sometime i dont , i forgot was the feeling before this leak so i want to know if it's normal sometime to feelt his shifts or there is something wrong.
Old May 27, 2011 | 07:43 AM
RobertG's Avatar
things with and without wheels
Your car has a transmission that has adaptive shift.If your transmission is not damaged due to that leak that you had repaired, you may want to try to clear it's memory and see if the shift has improved.
Old May 27, 2011 | 11:31 AM
Silver C's Avatar
C240
Try resetting the adaptive shift as stated, if problem doesnt go away after 1 week of driving then you better have it checked.
Old May 27, 2011 | 03:51 PM
c240
that's what i did but i have 2 more question, i red if you clear the adaptive transmition memory you have to keep the car running for 10 min a least with out turning the engine off, or the old values will return back , is that true or it's not the case cause i dont think that i drove the car for 10 min after the reset i drove home and turn it off and my home is near the shop.
second how can i know if the transmition is damged...
third i dont know if it's a bad shift or it's normal it's not hard shifting but you can feel the car changing shift is that normal???? i am frustrated
Old May 27, 2011 | 07:38 PM
Glyn M Ruck's Avatar
Super Moderator
If the transmission is slipping it will throw a code - Code: P2502 = The gear is implausible or the transmission is slipping - and put the car in limp mode to protect it.
Make sure that you have the fluid level correct for the temperature.
When last did the transmission have a service? Fluid & filter change - should be done every 39,000 miles or 60,000 Km.
It might be a good idea to drop the transmission pan & check the filter pickup for wear debris.
Old May 28, 2011 | 02:16 AM
c240
nothing is slipping , no faults codes, no limp mode just felling the shift and it's not hard i just checking is this is normal
PS: i changed the filters an oil .
Old May 28, 2011 | 01:35 PM
Super Moderator
I think you are OK
Good luck!
Old May 29, 2011 | 03:48 PM
c240
thx guys ! after one week of the memory adaptive transmition the car looked fine . hope i will help you in another topics
Old May 30, 2011 | 08:14 AM
c240
guys sorry but how to post a new thread i cant post or i dont know fromm where can i post a new thread
Old May 30, 2011 | 04:36 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Go" back" one page & see "New Thread " top left hand side.
