C180 Kompressor engine swap
Old Jun 14, 2011 | 10:12 AM
The Tokolosh's Avatar
Mercedes C180
Hi,
I have just aquired the above vehicle with a seized engine. I have access to another engine with block and head. I am looking at replacing the engine and just adding the ancilliarly parts from the old engine.
My question is, how do I stand with the ECU and security system?
Can I just use the system on the old car and just change the engine?
Will the ECU require resetting from a dealer or will it just be a straight swap ie. new engine in turn key and it starts?
Thanks for your help.
Old Jun 14, 2011 | 05:09 PM
Glyn M Ruck's Avatar
Super Moderator
If you are using all the electronics from the old car you should be fine with doing a sub assembly & head change.
Old Jun 15, 2011 | 03:37 AM
Mercedes C180
Hi Glyn,
Thanks for the advice. I kind of suspected that I might get away with it but had to factor any visit to the stealership before going ahead.
Many thanks,
Warren
Old Jun 30, 2018 | 10:55 AM
Ajti prince's Avatar
Mercedes w203 c180 kompressor
So is it possible to do a clean swap from 180 kompressor m271 to a 200 kompressor m111 w203 without changing the ecu? Can i just plug and play?
