Oil leaks
Old Jun 16, 2011 | 03:06 PM
coopershawk's Avatar
2007 C280
Oil leaks
My 2003 C320 Sports Coupe (with 96,000 kms...57,600 miles) has developed several oil leaks and the estimate from the stealership is as follows:
!. Main bearing oil seal: $878.60 (parts and labor)
2. Oil pan gasket: $595.26 (parts and labor)
3. Valve cover gasket $261.09 (parts and labor)
Total: $1734.95
Has anyone had these items done and if so, are these estimates out of line?
Thanks!
Old Jun 16, 2011 | 04:00 PM
Moreira_C230's Avatar
2006 C230 SS
Do you know where exactly the oil leak is coming from, or is it a combination of all those things?
Old Jun 16, 2011 | 04:48 PM
2007 C280
Apparently oil is coming from a combination of the 3. It's not too bad but I've noticed more on the garage floor recently.
Old Jun 17, 2011 | 12:28 AM
samaritrey's Avatar
Super Moderator
THE C350
You never really notice a leak with our cars because they have the plastic shields.
Old Jun 17, 2011 | 03:32 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I am a little sceptical that your car has developed 3 oil leaks all at once. Main brg & oil pan could be one of the same.
I would either check where the oil is coming from myself or receive another opinion from a reliable independent mechanic before spending all that hard earned.
Old Jun 17, 2011 | 01:09 PM
Silver C's Avatar
C240
Remove the Plastic pan, clean all the supposedly leaking area. Wait for 3-4 days and check the areas again. If the oil residue builds up again, then you have the correct leaking spot(s).
Old Jun 18, 2011 | 02:44 PM
samaritrey's Avatar
Super Moderator
THE C350
+1
