how to replace Camshaft Bolt
Old Jun 26, 2011 | 07:51 PM
xavier.rivera's Avatar
c230 kompressor
Hi
I need to replace the Camshaft Bolt part 271 050 01 71. I have a 2005 c230 k and after replacing the Cam Timing Adjuster Magnet give erro P0010 "A" Camshaft Position Actuator Circuit (Bank 1) and P0013 "B" Camshaft Position - Actuator Circuit (Bank 1).
any help will be appreciate
Old Jun 27, 2011 | 03:54 AM
W203E35's Avatar
2006 C350 Sport 6MT
I'm sorry I'm not familiar with the M271 motor but here are the documents that I have for the camshaft.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 27, 2011 | 07:55 AM
c230 kompressor
thanks for the information
Old Jun 27, 2011 | 10:35 PM
ambit's Avatar
09 CLK550
While replacing the intake valves on my old C230 I broke the front of the that exact camshaft bolt off removing the cover plate:
My friend removed the cam sprocket:
And used this genuine OEM Mercedes tool to hold the back of the cam vertically while twisting the front nut off:
MB P/N: A 203 *** ED UP
Old Jun 27, 2011 | 10:44 PM
c230 kompressor
wow thanks i buy them today maybe arrive tomorrow so i will start working on it.
Old Jun 27, 2011 | 10:51 PM
ambit's Avatar
09 CLK550
On a more serious note:
If the cam is still in the car and you just need to loosen/remove the bolt off the end there should be some flat sides you can put a wrench on and twist it off.
If you have both cams exposed you might want to put a wrench on both. One to hold it steady and the other to apply power. Otherwise the engine might try to turn over as you turn 1.
Old Jun 16, 2017 | 06:28 AM
Ruskisamoiloff@'s Avatar
Mercedes c200 2005
M271 camshaft bolt
Hi i was just wondering if i need to use the special tool to take this bolt off and if so does anyone have a link where i could buy one please.
Old Mar 21, 2024 | 09:29 PM
Deexrod3104's Avatar
2004 c230k m271 1.8L
Ayy bro did you figure out if you need the alignment tool kit just to get off the cam bolt ? I just need to get the bolt off too to clean but not tryna order and wait for the tool kit if I don’t need to take anything else off
Old Mar 22, 2024 | 08:04 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Tryna?
Old Mar 23, 2024 | 12:25 AM
Jaycat
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
