Replacing driver side frOnt lower rear control arm
Old Jun 28, 2011 | 12:16 PM
c240classic's Avatar
2007 cls63 AMG
Hi, has anybody done this themselves? Seems like it is only attached at two points. Does it come off relatively easily? Anybody have any pictures from under the car to show what it looks like. Thanks
Old Jun 28, 2011 | 01:55 PM
eesjunin's Avatar
Nowhere ...Fast
I have...pretty straight forward...i dont have ay pictures...buti belive to remove either the front or the rear FRONT control arm you would have to disingage the strut at the "spindle"...as memory serves me well i think its T40 that you will need
Old Jun 28, 2011 | 02:40 PM
2007 cls63 AMG
I think the strut needs to be moved aside for the lower front control arm thats pops upwards. I am looking at replacing the rear one which once the nut is taken off, pops downwards. How did you pop out the ball joint once you took the nut off ? Fork seperator and a big hammer ?
Does it need alignment after replacing it? i dont see it changing any adjustments but not really sure. thanks.
Old Jun 28, 2011 | 03:06 PM
eesjunin's Avatar
Nowhere ...Fast
i recall taking the lowere part of the strut off since you had to get to the nut holding the control arm...but yes fork and a hammer...i did an allignment after that... but you canusually tell if you need it done or not
Old Jun 28, 2011 | 08:45 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
Yes, you need to do an alignment afterwords. I would also recommend replacing the other side as well so they both match. I would see if you can find a place that does a free alignment check. Mercedes does say you don't need an alignment after replacing either the arms or the bushings, but I had just the bushings replaced on my old C230 and the whole arms replaced on my C55 and both times my steering wheel was off-center afterwords.
Old Jun 29, 2011 | 12:23 AM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
You dont need to remove the strut to remove the lower control arm. It's easier to get to the ball joint nut with the strut disengaged, but it can be done without.
Replacing the upper control arm on the other hand definitely needs the strut to be removed and moved aside.
