Eibach sways on sedan
Old May 29, 2003 | 11:54 AM
peet's Avatar
09 C63
Had any of you installed the W203 sways from eibach (listed as for coupe) on the sedan? They should fit, but I haven't yet gotten a definitive answer - EVEN FROM EIBACH! youwch.
Please help. I really want to buy this but would hate to find out if it was not a workable solution.
P
Old May 29, 2003 | 01:35 PM
K9ff's Avatar
08 E63
I had these installed about 3 months ago now.... no problems so far as I am wondering if the stock end links will break or not. only problem with the sways is a slight squeak i think since the bushings are polyurathane opposed to rubber stock(i put alot of the lubrication on them too)...
The Eibachs were designed for the coupe, but fit on the sedan with no problems, the R & D on the sways may be designed for a hatchback opposed to a sedan though, but handling definately seemed to improve on turns for the 02 c240 with H&R springs and stock shocks with 18s.
The only thing that may possibly go wrong is that the Eibach as well as Mercedes warranty will not apply if anything breaks related to the part installed, since Eibach lists the part only for the coupe and the factory will not cover since it is not a mercedes part.
hope this helps
Old May 29, 2003 | 03:27 PM
mdp c230k's Avatar
2002 c230k
Stock end links are strong enough to hold.
