clk springs for w203
Old Jul 18, 2011 | 12:30 PM
fran6co's Avatar
C240
oem SPRINGS FROM 2003 CLK 500 is it good for my c240 2002 ?,i want to lower my front gap ....need advice
Old Jul 18, 2011 | 01:49 PM
bheng's Avatar
2003 CLK 320
wont happen. consider that the springs for a clk500 will withstand the weight of the v8 engine vs the 2.5v6. if you want to lower, you might consider getting aftermarket or if you want to keep oem, have an auto shop cut them (not the recommended option)
Old Jul 18, 2011 | 01:52 PM
havoc_vulture's Avatar
'05 c230 Kompressor SS Mistress
Or get a post facelift w203 with the sport suspension and use the suspension off that. It is lower than the avant-garde and luxury suspensions from other w203s maybe an 05+ sometimes they have then in the classifieds
Old Jul 18, 2011 | 03:51 PM
samaritrey's Avatar
Super Moderator
THE C350
+1 to all above
OEM sport springs/shocks or Go for aftermarket.
Old Jul 18, 2011 | 05:19 PM
fran6co's Avatar
C240
im looking for that .....is the c 32 suspension ok ?
Old Jul 19, 2011 | 12:25 AM
samaritrey's Avatar
Super Moderator
THE C350
c32 would be fine.
Old Jul 26, 2011 | 04:37 PM
chkoo's Avatar
W211 E63, W205 C300
i have h&r clk springs
Old Jul 26, 2011 | 06:57 PM
phister's Avatar
06 C230 SS 6spd
C32 springs are actually higher than the SS springs. If you cut your stock springs be careful cause you'll be changing the spring rate on the springs and the handling will be compensated over time. Just look for a set of used SS springs in the classified section. People usually sell the whole set for less than 200.
Old Aug 1, 2011 | 02:20 PM
C_280's Avatar
C280
i was told that clk springs are lower than the sport springs on a c? when i bought ss springs from someone on here, they gave me clk springs for free with it and told me itll be lower than the sport suspensions. can anyone confirm this?
Old Aug 1, 2011 | 03:30 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I may be willing to part with my OEM springs from my '05 C230 if the price is right. Only thing is you would have to get the front and rear.
