Rear Differential Fluid change question
Old Jul 19, 2011 | 11:40 AM
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
Wanted to do this job last weekend but could not get the fill plug open.
My question to all you peeps is, how does one open the fill plug? What does it look like? do you need special tool to open this? if not then what tool to use , an allen key etc etc???
I cannot feel any hex profile when I touch the fill plug located on top of the diff assembly, I feel that there is a hole on top of the fill plug but was unable to fit any size allen key in that hole. So how does one open this fill plug???
Any help / guidance would be helpfull..........If any one has a schamatic diagram of what the fill plug looks like even that would help understand wheather mine is stripped or not???
please help...
Javvy
Old Jul 19, 2011 | 11:46 AM
Milkm4n's Avatar
2006 c230
https://mbworld.org/forums/c-class-w...-write-up.html
Old Jul 19, 2011 | 11:48 AM
Milkm4n's Avatar
2006 c230
there you go man that should help, someone should sticky that if it isn't already i got it from page 4 of the w203 thread.
Old Jul 19, 2011 | 12:38 PM
Javvy's Avatar
thanks milkman.........I was looking at the wrong place for the fill plug...........as a normal human being I was looking for it at the top.........now it makes sense..........it is on the side on the driver side and the drain is at the bottom on the passenger side.........
appreciate the help ............and please I would also vote for this to be put up in the sticky as a DIY as I have seen of late a lot of people asking questions on the Differential service..
Javvy
