COMAND Question....need help..
Old Jun 3, 2003 | 12:10 PM
rsyed's Avatar
C200 CDI w203
Hi!
Do a simple test, take the speed wire from where you have it into teh car, but do not connect it! Check while driving wiht an oscilloscope whether there is a signal while driving! Like that you eliminated the problem with whether you have a speed signal or not!
There is no point of doing an update as you have to have the system up and running before any update is worthwhile! IF the comand (and that is only IF) was working when you bought it, then you should have to simply connect the CAN bus wires correctly and the speed signal! My suggestion, test teh speed signal to see whether you have got the right socket 24, pin 3!!
regards, Rumman
ps. sorry i did not reply to your mails as i am currently in boston and have limited mail access to my account in vienna!!
Old Jun 3, 2003 | 01:15 PM
nellee's Avatar
2002 CLK320
easy fix, yank the comand out and ebay it....
hook up with Steve on his next trip and let the master take care of it. You won't have to deal with this agony any longer.
Old Jun 5, 2003 | 12:17 AM
aerodragon's Avatar
guys...
all the problems are solved....
thanks...
Old Jun 5, 2003 | 10:35 AM
rsyed's Avatar
C200 CDI w203
and what was the problem at the end? let me guess, incorrect speed signal
greetings Rumman
Old Jun 5, 2003 | 11:30 AM
aerodragon's Avatar
yup Rumman...sorry for the many emails
Old Jun 5, 2003 | 12:25 PM
rsyed's Avatar
C200 CDI w203
and how did you figure out, trial and error or with an oscilloscope??
regards, Rumman
ps. ask steve for the dvd adapter, he should have one, i don"t think he will disappoint you as he usually has everything a merc may need!
