Can I use the power from cd changer to splice extra cigarette plugs?
Old Jul 31, 2011 | 07:50 AM
essze's Avatar
c55
Is it possible for me to splice the power cable from the cd changer to add extra cigarette plugs in the glove box? or do i have to splice from the center console cigarette outlet *** i wanna add a bluetooth receiver in the glove box connect to the aux. thank you
Old Jul 31, 2011 | 11:44 AM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
It is a big job but I would take the power from the existing console outlet, you want to do a proper job, the existing outlet will have a larger fuse and heavier wire to begin with and will take a heavier load. I added a 3 outlet 12v with a usb powered outlet to charge my ipod. The 3 outlet is screwed in from behind the glove box to make the install look professional and OEM. You can never have enough outlets and the German car companies are slowing discovering that. I use all of them:
1. GPS
2. radar detector
3 phone charger
USB. iPod
Attached Thumbnails Can I use the power from cd changer to splice extra cigarette plugs?-img_1196.jpg   Can I use the power from cd changer to splice extra cigarette plugs?-img_1199.jpg   Can I use the power from cd changer to splice extra cigarette plugs?-img_1208.jpg   Can I use the power from cd changer to splice extra cigarette plugs?-img_1203.jpg
Old Aug 1, 2011 | 08:47 AM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Great work!! That's really cool and well done. From the pictures, it looks like it was A LOT of work to do it!
Old Aug 1, 2011 | 01:01 PM
Boom vang's Avatar
and everything went back perfectly, aligned with no squeaks or rattles and has been that way for 2 years now
While I had everything out I also put in an FM modulator for my ipod that taps directly in to the car antenna and buried the cable for my Garmin GPS
Attached Thumbnails Can I use the power from cd changer to splice extra cigarette plugs?-img_1212.jpg
Old Aug 1, 2011 | 02:28 PM
essze's Avatar
c55
thats nice job Boom Vang, so is it possible if i splice it to a outlet like the wall plug instead of cigarette plug? *** i wanna plug it to a bluetooth connector
Old Aug 1, 2011 | 04:01 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Wall plug? As in the same type of plug inside a building?
If that's what you mean, then yes it's possible to wire that up... But cars and buildings use different types of electricity, and installing an A/C "wall plug" into a car is a bad idea. You can install a power inverter, which will convert the cars D/C electricity to A/C, which you can plug things into.
Old Aug 1, 2011 | 08:35 PM
Glyn M Ruck's Avatar
Super Moderator
You can always take power from the Cabin fuse box as an alternative.
Attached Thumbnails Can I use the power from cd changer to splice extra cigarette plugs?-p1070698r.jpg
