New Wheels Lug nuts are too long!!!
Old Aug 12, 2011 | 07:50 PM
zim-c350's Avatar
2010 C350
I had purchased 18x8 wheels with a 35 offset but the lug nuts I have are a little too long and are hitting the ebrake parts in the rear. The hub bore is 66.6. How do I figure out which size lug nuts I need or would I need a spacer?
Old Aug 12, 2011 | 07:57 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
OEM wheels or replica?
OEM lug nuts or replicas?
There are numerous posts on here explaining the difference.
Old Aug 12, 2011 | 08:18 PM
LawRens's Avatar
43
are you driving a w203 or w204? You posted in the w203 section, yet in your descript your car is a w204 c350. ?___?
Old Aug 12, 2011 | 09:56 PM
zim-c350's Avatar
2010 C350
Sorry just purchased a 03 C320 4matic. Its replica 18" amg wheels and im pretty sure the lug nuts are oem. The rear lug nuts are hitting the parking brake springs in the rear.
Old Aug 13, 2011 | 03:47 AM
phister's Avatar
06 C230 SS 6spd
Get the OEM lug and put one in your OEM wheel and measure how far it sticks out from the other end. Now put the same lug and put it in your new wheel and measure how far it sticks out. Subtract the difference so you know how much less you need. Factory bolts shanks are 39.9mm long. Also when you first catch your lug bolt onto the thread it should take 6 full turns to tighten it.
Old Aug 15, 2011 | 04:17 PM
fran6co's Avatar
C240
i cut mine and #1
