SPLASH!!!
The Front, Driver Side plastic splash shield [# A2038840722]came loose and was rubbing against the tires while I was on the road and now its unusable.
My question is.. Since it rains here in FL everyday, will it affect anything electrical on the car if the area gets wet? I'm seeing some wires/connections on there and I'm worried about using the car before the part arrives.
Thanks all.
I believe a replacement at the dealership is about $30 FYI.
Thanks all.
everything inside your engine bay is waterproof/water tight so you'll be fine. The only thing I would worry about is if you drive in the snow due to salt/sand etc etc but you'll be fine.
Just ordered the part at RMEuropean for $32.40.
I hope #203-881-03-23 is the new updated part #. It's stamped A203 884 0722
on the shield itself...guess ill find out.
