for Lynn..Euro--> US time change
Old Jun 2, 2003 | 09:43 PM
aerodragon's Avatar
Lynn.
could you please post or email me the steps to change Euro Comand for US timing?
thanks
Old Jun 2, 2003 | 10:36 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Make sure you have GPS reception before you start!!!
push the SYS button...go to settings, then to time/date, go to the displayed minutes and push the right knob once after which you can set the time per 30 minutes untill you have the proper time on the screen...
greetingz,
Old Jun 2, 2003 | 10:43 PM
aerodragon's Avatar
steve...I think I did try it...and it worked fine..at the first time or just for a moment
however after I restarted the engine..it was reset back to Germany time (including my cluster time)
Old Jun 3, 2003 | 12:22 AM
Lynn's Avatar
As Steve said, make sure you are receiving signals from the GPS satellites.
1. Press the "SYS" button.
2. Turn the right rotary knob to highlight "Language".
3. Press knob.
4. Turn the right rotary knob to highlight "English (metr.)" if you want distances in meters and kilometers or "English (imp.) if you want distances in yards and miles.
5. Press knob.
6. Turn the right rotary knob to highlight "Settings".
7. Press knob.
8. Turn knob to highlight "Date/Time".
9. Press knob.
10. Turn knob to highlight "Country (Time)".
11. Press knob.
12. Turn knob to highlight "Country List".
13. Turn knob to highlight "United Kingdom".
14. Press knob.
15. If there is a check mark in the box next to "Autom. SW Time", press the knob. If no check mark do not press the knob.
16. Press the knob and hold down until you hear a beep and the screen changes. Greenwich Mean Time is in the display.
17. Turn the right rotary knob to highlight "Settings".
18. Press the knob.
19. Turn knob to highlight "Date/Time".
20. Press the knob.
21. You will see the GMT dat and time displayed with the seconds shown as black numerals in a white box. Press the knob and the numerals will turn red.
22. Turn the knob until you see the correct date and time.
23. Press and hold the knob until you hear a beep and the screen changes to the main SYS screen.
Old Jun 3, 2003 | 04:32 AM
MBenzNL's Avatar
some slow@$$diesels
Setting the time before you have full GPS reception (and thus an automatic generated country time) does not work...comand will overrule whatever you entered as soon as it gets GPS reception (hence the reason why you need to have GPS reception before setting the time).
greetingz,
