engine crank / no start
the engine crank and start for few second and after he stall and don't start.
no code appear and when I start the rpm rest to 0.
(I will see on forum,if the rpm rest to 0 when I start, probably the problems is the crank sensor???)
the fuel filter have one year and the plug are new.
I dont have problems with the engine before
thank s for your help
will
Likely cause is CPS.
Check fuel pressure - It should be 3.8 bar.
See 14
The easiest way to check the pump is to take the pressure line to the filter & place it in a jar. It should pump a litre of fuel in about 40 seconds.
You can test it outside of the vehicle by applying 12V across the coil (85 and 86), and you should hear the relay click and have continuity between 30 and 87.
I unplug the hose before the fuel filter and I start,it does not have fuel from the hose...
I think the pompe is the problem...what do you think on that
Seems your pump is dead.
