w203 under panels
Old Aug 28, 2011 | 04:48 AM
EnDLeSs_27's Avatar
2002 C230
w203 under panels
Does anyone know the part numbers for the underpanels on a 2002 C230k
I just had the dealer inspect my car and they said I am missing the under panels. The only underpanel I have is the one that goes directly under the engine.
There seems to be I think 2 more larger underpanels that are missing that cover the drivers side and passenger side.
Old Aug 28, 2011 | 08:31 AM
phister's Avatar
06 C230 SS 6spd
Go to rmeuropeam.com they have all the body panels. Just enter your cars info and itll be under body then go to fender liner and youll see the panels you want.
Old Aug 30, 2011 | 07:00 PM
EnDLeSs_27's Avatar
2002 C230
Its not there. I searched and only found the shield that goes directly under the engine.
Old Aug 31, 2011 | 03:21 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
go to the MB Electronic Parts Catalog (EPC). Its available to you at no charge. Just put in your VIN and you can find anything for your car.
Old Aug 31, 2011 | 04:43 AM
phister's Avatar
06 C230 SS 6spd
I went directly to it. Did you go to fenders on the left side?
Old Aug 31, 2011 | 12:07 PM
EnDLeSs_27's Avatar
2002 C230
Yea, I already have that. I have been searching endlessly in their to find it. I just cant find it. Where would I have to look to find the under panels for the car? (not for the engine)
Old Aug 31, 2011 | 02:37 PM
phister's Avatar
06 C230 SS 6spd
here they are in rmeuropean... its under fender liner.
http://www.rmeuropean.com/Part-Numbe..._5C1313F8.aspx
Old Aug 31, 2011 | 04:26 PM
amanonfire's Avatar
W203
I think he means the 4-5' long panels under the car by the doors. I needed new ones, damaged mine, and couldn't easily find them to buy. Plus I suspect shipping would cost a small fortune.
If there's a wrecker/used auto parts store close by ask them, I bet you can pull them from a wreck for pennies of trying to find them new.
Old Aug 31, 2011 | 05:29 PM
EnDLeSs_27's Avatar
2002 C230
Originally Posted by phister
Ya not looking for those shields. Need the longer ones that basically cover everything else underneath the car.
Mine just happened to be missing. Not sure where it went. I am missing the passenger side one only though.
Old Aug 31, 2011 | 09:40 PM
Glyn M Ruck's Avatar
Super Moderator
10 A 203 610 05 60 BOTTOM
LEFT [409]
001
20 A 203 610 06 60 BOTTOM
RIGHT [409]
001
100 A 203 610 03 10 SIDE MEMBER
INSIDE LEFT 001
110 A 203 610 04 10 SIDE MEMBER
INSIDE RIGHT 001
120 A 203 612 01 14 CROSS MEMBER
BELOW FRONT SEAT,FRONT LEFT 001
130 A 203 612 02 14 CROSS MEMBER
BELOW FRONT SEAT,FRONT RIGHT 001
140 A 203 612 03 14 CROSS MEMBER
BELOW FRONT SEAT,REAR LEFT 001
150 A 203 612 04 14 CROSS MEMBER
BELOW FRONT SEAT,REAR RIGHT 001
160 A 203 616 01 31 CONSOLE
FRONT SEAT CROSS MEMBER 002
170 A 203 619 01 25 STIFFENING
FRONT SEAT CROSS MEMBER Code: 423/424
001
170 A 203 619 01 25 STIFFENING 001
170 N 000000 0003853 SCREW
M8X16 002
180 N 000000 0003853 SCREW
STIFFENING TO BODY
M8X16 Code: 423/424
002
M8X16 002
190 A 203 616 01 47 TAKE-UP DEVICE
PROPELLER SHAFT BEARING IN TUNNEL CENTER [002], [003], [004]
001
190 A 203 616 03 47 TAKE-UP DEVICE
PROPELLER SHAFT BEARING IN TUNNEL CENTER [005], [006], [007]
001
300 A 203 619 01 38 COVER
BELOW MAIN FLOOR,LEFT
Replaced_By: A 203 619 11 38 001
300 A 203 619 11 38 COVER
BELOW MAIN FLOOR,LEFT 001
310 A 203 619 02 38 COVER
BELOW MAIN FLOOR,RIGHT
Replaced_By: A 203 619 12 38 001
310 A 203 619 12 38 COVER
BELOW MAIN FLOOR,RIGHT 001
320 A 201 990 00 50 NUT
COVERING TO FLOOR 016
10 A 203 610 05 20 CROSS MEMBER
CROSS MEMBER BELOW REAR SEAT 001
20 A 203 610 08 61 BOTTOM
UNDERNEATH REAR SEAT 001
30 A 203 618 05 16 REINFORCEMENT
SEAT BELT ATTACHMENT 001
40 A 203 610 07 14 CROSS MEMBER
LOADING FLOOR,LEFT 001
50 A 203 610 08 14 CROSS MEMBER
LOADING FLOOR,RIGHT 001
60 A 203 610 01 16 CROSS MEMBER
ABOVE REAR AXLE 001
70 A 203 610 00 52 TAKE-UP DEVICE
REAR AXLE MOUNTING,FRONT
Replaced_By: A 203 610 13 52
+001 A 000 990 43 03 [008], [009], [010]
002
70 A 203 610 13 52 TAKE-UP DEVICE
Replaced_By: A 203 610 14 52 [011], [012], [013]
002
70 A 203 610 14 52 TAKE-UP DEVICE
REAR AXLE MOUNTING,FRONT [011], [012], [013]
002
75 A 203 610 00 36 HOLDER
REAR BACKREST Code: 287
002
77 A 002 984 33 29 SCREW
BRACKET MOUNTING
M8X24 Code: 287
004
80 A 203 610 07 10 SIDE MEMBER
REAR CENTER TOP LEFT 001
90 A 203 610 08 10 SIDE MEMBER
REAR CENTER TOP RIGHT 001
100 A 203 610 01 10 SIDE MEMBER
REAR LEFT 001
110 A 203 611 00 21 .SIDE MEMBER
REAR LEFT [014], [015], [016]
001
120 A 203 610 02 10 SIDE MEMBER
REAR RIGHT 001
130 A 203 611 14 21 .SIDE MEMBER
REAR RIGHT 001
140 A 203 610 17 25 REINFORCEMENT
LEFT SIDE MEMBER Code: 550
001
150 A 203 610 18 25 REINFORCEMENT
RIGHT SIDE MEMBER Code: 550
001
160 N 910104 4010001 NUT
REINFORCEMENT TO SIDE MEMBER
M10 Code: 550
004
160 N 000000 0002574 MULTIPLE NUT
CROSSMEMBER MOUNTING
M8 Code: 550
004
170 N 000000 0001556 SCREW
M10X25 Code: 550
004
170 N 000000 0001557 SCREW
M10X60 Code: 550
002
180 A 203 610 05 26 SIDE MEMBER
CONNECTION PIECE LEFT 001
185 A 203 611 01 31 .CONSOLE
LEFT 001
190 A 203 610 06 26 SIDE MEMBER
CONNECTION PIECE RIGHT 001
195 A 203 611 02 31 .CONSOLE
RIGHT 001
200 A 203 610 11 26 END PIECE
REAR LEFT 001
210 A 203 610 04 26 END PIECE
REAR RIGHT 001
220 A 203 610 03 76 WHEELHOUSE
REAR LEFT 001
230 A 203 610 04 76 WHEELHOUSE
REAR RIGHT 001
250 A 203 610 02 75 SPARE WHEEL WELL 001
260 A 009 997 29 81 GROMMET
WATER DRAIN IN SPARE WHEEL WELL
26 MM 001
270 A 168 670 00 93 REPAIR KIT
280 A 203 619 07 38 COVER
TANK PUMP 002
280 A 203 619 07 38 COVER Code: 929
001
300 A 203 619 00 38 COVER
FOOT OPERATED PARKING BRAKE 001
310 A 001 987 70 46 SEALING CORD
TO COVER FOR TANK PUMP [404]
NB
Code: 929
NB
TO FOOT OPERATED PARKING BRAKE COVER [404]
NB
320 A 203 990 00 36 SCREW
M5X10 012
M5X10 002
You say you are not interested in the engine cover or front valance cover so I have not posted.
Attached Thumbnails w203 under panels-front-floor.jpg   w203 under panels-rear-floor.jpg
Old Sep 1, 2011 | 10:17 PM
EnDLeSs_27's Avatar
2002 C230
okay I found a picture to help describe my situation a little more.
I am looking for the long plastic under cover panel that goes on the passenger side. This picture is NOT how the under cover should look like. But it shows where the panel should go.
Old Sep 2, 2011 | 10:39 AM
shan's Avatar
W203 (2007), W120 (1962)
It is not 2 pieces. It is a single piece, starting with 2 common screws with the ends of the front panel and held by 2 more screws at the back. It covers the engine oil and ATF sumps.
Shan.
Old Sep 2, 2011 | 10:50 AM
Super Moderator
300 & 310 in the diagram above. Both sides.
Old Sep 2, 2011 | 01:36 PM
amanonfire's Avatar
W203
What sometimes happens is they come loose, fall down, become damaged. The easiest solution is to then just remove the entire panel and live without it.
You don't really need it, and for the cost/hassle/shipping to get one I'd just leave it as is. I have a request in with my local junkyard if they have a C-coupe come in to let me know, I need a few parts like this that would be cheap to pull from a wreck, yet cost a fortune to buy/ship new.
Old Sep 8, 2011 | 02:50 AM
EnDLeSs_27's Avatar
2002 C230
Thanks for clarifying it. I saw those while I was browsing EPC but thought it is was part of the interior.
I'm starting to agree with you. The cheapest I found would cost $150ish. for the right side only.
Old Sep 8, 2011 | 08:39 AM
Super Moderator
They are there for aerodynamic reasons to keep airflow under the car smooth.
Old Sep 8, 2011 | 08:59 AM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
They also help keep the engine compartment, tranny, etc. clean. I like them. If mine get damaged, I might spend $150 for new ones, but I'd look in salvage yards first as amanonfire suggested.
Old Nov 12, 2018 | 11:45 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Can somebody please post the PN for the L side underbody panel for a LHD 2003 W203 coupe? I'm having the same problem as the OP. Nobody seems to know the part number for this thing.
I would imagine the coupe uses different panels from the sedan, which are listed above.
Thanks in advance.
