Identify these parts for me pls !
Really ugly bruise caused while exiting a narrow garage last winter. Not the original picture, but can someone please identify :
1. The part circled in Red. It looks like its a single part that can be replaced.
2. Also the horizontal running aluminum trim has come off, it seems their were 3-4 clips below it which broke.
Any suggestions on where to buy online would be appreciated.
thanks - K
[/IMG]110 A 203 698 01 54 PANELING
LEFT [022], [023], [024], [133]
001
110 A 203 698 13 54 PANELING
Code: 954
001
LEFT [025], [026], [027], [133]
001
110 A 203 698 17 54 PANELING
LEFT [133]
Code: 772
001
110 A 203 698 02 54 PANELING
RIGHT [022], [023], [024], [133]
001
110 A 203 698 14 54 PANELING
Code: 954
001
RIGHT [025], [026], [027], [133]
001
110 A 203 698 16 54 PANELING
RIGHT [133]
Code: 772
001
10 A 203 690 47 62 PROTECTIVE STRIP
LEFT, FENDER FRONT [922]
Code: 955/954/772/040+460/772+953
001
10 A 203 690 02 62 PROTECTIVE STRIP
RIGHT, FENDER FRONT [922]
001
10 A 203 690 48 62 PROTECTIVE STRIP
001
15 A 011 988 28 78 .CLIP
LEFT Code: -900
002
RIGHT Code: -900
002
20 A 001 988 76 81 .PUSHBUTTON
LOWER PART, LEFT Code: -900
002
LOWER PART, RIGHT Code: -900
002
22 A 203 817 09 20 GUIDE SIGN
PANELLING TO FRONT FENDER Code: -265
002
24 A 203 817 10 20 GUIDE SIGN
PANELLING TO FRONT FENDER Code: -265+955
002
26 A 203 817 11 20 GUIDE SIGN
Replaced_By: A 211 817 48 20 Code: -265+954
002
26 A 211 817 48 20 GUIDE SIGN
PANELLING TO FRONT FENDER Code: -265+954
002
30 A 203 817 29 21 GUIDE SIGN
PANELLING TO FRONT FENDER Code: -265+953+P84/-265+954+P84/-265+955+P84/-265+953+P85/-265
002
---- PART NAME MISSING Code: +954+P85/-265+955+P85
000
40 A 203 690 21 62 PROTECTIVE STRIP
LEFT, CENTRAL FRONT DOOR [922]
001
40 A 203 690 49 62 PROTECTIVE STRIP
Code: 955/954/772/772+953/040+460
001
40 A 203 690 22 62 PROTECTIVE STRIP
RIGHT FRONT DOOR, CENTRAL [922]
001
40 A 203 690 50 62 PROTECTIVE STRIP
001
50 A 203 690 29 62 PROTECTIVE STRIP
LEFT REAR DOOR, CENTRAL [922]
001
50 A 203 690 51 62 PROTECTIVE STRIP
001
50 A 203 690 30 62 PROTECTIVE STRIP
RIGHT REAR DOOR, CENTRAL [922]
001
50 A 203 690 52 62 PROTECTIVE STRIP
001
55 A 008 988 21 78 .CLIP
PROTECTIVE TRIM ON DRIVER DOOR, LEFT 001
PROTECTIVE TRIM ON DRIVER DOOR, RIGHT 001
PROTECTIVE TRIM ON REAR DOOR, LEFT 001
PROTECTIVE TRIM ON REAR DOOR, RIGHT 001
60 A 007 988 71 78 .CLIP
48 X 28.4 MM Code: -900
003
003
48 X 28.4 MM 003
48 X 28.4 MM 003
60 A 011 988 27 78 .CLIP
45.9 X 24.8 MM 002
45.9 X 24.8 MM 002
65 A 009 988 95 78 .CLIP
PROTECTIVE TRIM ON DRIVER DOOR, LEFT Code: -900
001
PROTECTIVE TRIM ON DRIVER DOOR, RIGHT Code: -900
001
70 A 203 984 05 29 SCREW
4.8X8 001
4.8X8 001
4.8X8 001
4.8X8 001
90 A 203 690 05 62 PROTECTIVE STRIP
LEFT, FENDER REAR [922]
001
90 A 203 690 53 62 PROTECTIVE STRIP
001
90 A 203 690 06 62 PROTECTIVE STRIP
RIGHT, FENDER REAR [922]
001
90 A 203 690 54 62 PROTECTIVE STRIP
001
93 A 011 988 41 78 .CLIP
LEFT, FENDER REAR 001
93 A 011 988 37 78 .CLIP
RIGHT, FENDER REAR 001
95 A 000 991 56 71 CLIP
100 A 203 690 85 62 LEDGE
(WATER DEFLECTOR),LEFT [912]
Code: -342-963
001
100 A 203 690 69 62 LEDGE
(WATER DEFLECTOR),LEFT [923]
Code: 954/955
001
100 A 203 690 86 62 LEDGE
(WATER DEFLECTOR),RIGHT [912]
001
100 A 203 690 70 62 LEDGE
(WATER DEFLECTOR),RIGHT [923]
Code: 954/955
001
101 A 203 690 00 13 CLIP
(WATER DEFLECTOR), TO ROOF FRAME 010
102 A 203 698 25 98 SEAL
(WATER DEFLECTOR),LEFT Code: -342-963
001
102 A 203 698 26 98 SEAL
(WATER DEFLECTOR),RIGHT 001
104 A 203 690 95 62 LEDGE
(WATER DEFLECTOR), LEFT FRONT [912]
Code: 342/963
001
106 A 203 690 97 62 LEDGE
(WATER DEFLECTOR), LEFT REAR [912]
Code: 342/963
001
107 A 010 988 59 78 CLIP
(WATER DEFLECTOR), TO ROOF FRAME 008
108 N 910001 1003101 RIVET
FASTENING CLAMPS
3.2 X 5.89 016
115 A 203 698 07 54 PANELING
IN FRONT OF REAR AXLE,LEFT 001
IN FRONT OF REAR AXLE,LEFT Code: 772
001
115 A 203 698 08 54 PANELING
IN FRONT OF REAR AXLE,RIGHT 001
IN FRONT OF REAR AXLE,RIGHT Code: 772
001
117 A 124 990 04 92 RIVET
LEFT PANELLING 001
RIGHT PANELLING 001
120 A 140 698 00 82 PIN
FASTENING, PANEL TO BODY, LEFT 004
FASTENING, PANEL TO BODY, RIGHT 004
130 A 009 997 72 81 GROMMET
AT PANEL, LEFT 010
ON TRIM,RIGHT 010
140 A 001 990 01 92 RIVET
AT PANEL, LEFT 010
ON TRIM,RIGHT 010
150 A 203 698 01 98 SEAL
TOP LEFT 001
TOP RIGHT 001
160 A 203 698 19 98 SEAL
AT PANEL, FRONT LEFT 001
160 A 203 698 20 98 SEAL
TO PANEL, FRONT RIGHT 001
170 A 203 698 07 98 SEAL
AT PANEL, REAR LEFT 001
170 A 203 698 08 98 SEAL
TO PANEL, REAR RIGHT 001
210 A 203 988 06 78 CLIP
IN LEFT SEALING DUCT 009
IN RIGHT SEALING DUCT 009
220 A 203 988 07 78 CLIP
LEFT Code: -772
002
RIGHT Code: -772
002
LEFT Code: 772
001
RIGHT Code: 772
001
230 A 203 988 08 78 CLIP
LEFT 001
RIGHT 001
240 A 203 988 09 78 CLIP
LEFT Code: -772
001
LEFT Code: 772
002
RIGHT Code: -772
001
RIGHT Code: 772
002
10 A 203 690 01 62 PROTECTIVE STRIP
001
Please ignore my ignorance. Can you please point out the part thats withing the red circle (highlighted in white) in the picture I uploaded. For some reason I cannot make out from the list.
thanks again -K
