DIFFERENTIAL DiFFERENTIAL
Old Sep 24, 2011 | 11:55 PM
danev6972's Avatar
2003 C240
Been bothered by a 'hushing' sound for a while every time I release the gas even very slightly. Usually happens around 40mph on. Sounds like a vacuum leak but my mechanic friend found it was the differential.
Some here in the forum says it is not uncommon & some says otherwise. Just can't believe that it will go bad that soon[ less than 90000mi.].
Pardon my ignorance. So there is a separate front & rear differential?
Noise seem to be coming from the front...
Will a diff oil change solve anything before I buy parts?
Found some on ebay: http://cgi.ebay.com/ebaymotors/MERCE...item2a0bb68852
http://cgi.ebay.com/ebaymotors/?cmd=...K%3AMEWAX%3AIT
One came off of 2003 MERCEDES KOMPRESSOR C230 don't know if that will fit my 03 c240sedan base.
Thanks for any input.
Old Sep 25, 2011 | 12:30 AM
samaritrey's Avatar
Super Moderator
THE C350
What the hell happened to that car dam
I guess your diff got low on fluid or something because I have never heard of a failure on here except for ones that had a leak. That said how did he confirm it was the diff making noise. I am not 100% sure about what diff fits but I think the c240 and c230 use a different gear ratio so you would need to check that.
Old Sep 25, 2011 | 12:55 AM
danev6972's Avatar
2003 C240
Never-ending problems with the car since I bought it in '06. I don't know how he confirmed his findings...I left him my car for a week while i was on vacation to find the problem. I may have to talk to him some more...He's a good friend & I don't think he'll BS me..I hope not.
Thanks Samaritrey.
Old Sep 25, 2011 | 01:04 AM
samaritrey's Avatar
Super Moderator
THE C350
Oh I would hope not as well but that is a big investment to go into if it is only a flex disc or something like that. I am no expert on the drive train but do know that sounds from it can be hard to track down sometimes and can sound like they are coming from an area that is actually far away from the issue. It will also help others that do know more to have as much detail as possible heck even a sound clip if possible.
As for you car you have had lots of issues I am sure that some cars are just lemons or something because they say 03 - 04 the w203 were getting way better than the 01's but it does not always seem like that around here. I will say my car was at the dealer a lot before my warranty ran out at 100k but that is just my OCD and using the warranty as much as possible but once I got everything fixed the dealer broke (Long Story) my car has been very very reliable with just a set of front break pads and rotors, new shocks/spring and that is really it. 166k almost 167k
Hopefully this is the end of your issues Good luck let me know if you want me to run your vin to get the exact PN of your DIF to help with the research of what years and models use the same Dif.
Old Sep 25, 2011 | 10:35 AM
JUAN CASAUS's Avatar
2005 E55 AMG
I would say to put it on a car lift and try to listen from under what is actually making the noise. If a diff goes bad it usually makes a clicking noise because the teeth are broken or chipping.
Old Sep 25, 2011 | 10:36 AM
2005 E55 AMG
Drain your fluid and see if there are any pieces of teeth. Its a cheap and ready job. There are diys on here for it.
Old Sep 25, 2011 | 12:11 PM
Glyn M Ruck's Avatar
Super Moderator
+1^ - drain oil & look for wear debris!
Old Sep 25, 2011 | 04:48 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Make sure oil is hot & check the oil level is where it should be before you drain into a very clean pan.
Good luck.
Old Sep 26, 2011 | 09:54 PM
danev6972's Avatar
2003 C240
Vin# PM'd.
I think my car had been in an accident. Bought the car on ebay(never again) from a dealer in ohio. When the car was delivered I did'nt get a chance to inspect it because I was out of town so my wife signed the delivery clearance for me.
Excited about the car, I didn't really do a thorough check but after awhile I noticed the hood & bumper did not line up for some reason. Believe me I had a carfax report that showed no accident. My bank even reviewed it before loaning me the $$$.
I'll see my mechanic this weekend and go from there.
Old Sep 29, 2011 | 07:23 PM
danev6972's Avatar
2003 C240
Sound clip here: http://www.youtube.com/watch?v=bxDXx6dEhuc
Subtle when windows closed but more pronounced around 2:00 mark into the vid.
Sounds like metal rubbing at times. The more I listen to it the more I get confused!! Inside the car windows closed sounds like a 'hush'. Like an air leak.
ONLY happens when I release the gas pedal.
Don't know if I should be driving the car or not. I'm supposed to be out of town this weekend. Damn!
Worn out rotors make that noise???
Found a cheaper one. http://cgi.ebay.com/ebaymotors/?cmd=...K%3AMEWAX%3AIT
Old Nov 3, 2011 | 08:18 PM
danev6972's Avatar
2003 C240
Hey all.
I found a rear diff on ebay & i'm emailed seller for positive compatibility.
My question is: Is 139k mi too high for a diff?
Part came off of a 2004 MERCEDES C CLASS C230.
http://www.ebay.com/itm/110644653331...S:1123&vxp=mtr
Need help guys..noise is getting louder.
Thank you.
Another one:
http://www.ebay.com/itm/180585138258...WAX:IT&vxp=mtr
