unwanted oil in engine...
As the pictures will show below, there is oil coming from somewhere in my engine. All the harnesses were replaced by the dealership and I recently replaced the spark plugs. The first spark plug was extremely oily and the second one was a bit oily upon replacement. Number 3 and 4 were dry. Upon removing number 1 plug last night, I saw oil again. Prognosis???
TIA
#1 is the closest to camera and #4 is farthest
#1 plug
Covered with oil
Oil accumulating in there! I had cleaned it out when i replaced the spark plugs
Minor leak from here too (right side)
Oil around the camshaft solenoid actuators, either snug up the bolts or refit a new o-ring - may not be seated properly
https://mbworld.org/forums/c-class-w...updates-4.html
basically even though i had my cam sensor replaced to prevent oil leaks... for some reason they didn't do it properly the first time and have to fix all the damage that was caused by the oil buildup
I have gotten my cam sensors replaced already. Gonna do a compression as per a friends recommendation...
i had mine replaced too, but because they didn't do a thorough inspection... it lead to all the problems that happened this week... and their was oil everywhere.
goodluck!
goodluck!
There are 2 cam sensor (CMP) and you will find them at these locations: The intake CMP is located opposite coil for cyl 3 and the exhaust CMP is on the right side of the cylinder head just below the valve cover and are made of plastic
Lets call the parts by the proper name or people will be looking for the wrong item
If you need to replace the cambox gasket use some Yamabond on it.
