Need help with my suspension
Old Nov 6, 2011 | 03:44 PM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
I'm having an issue with the front suspension.
When I'm driving, and hit a man hole, or some small divot in the road, the steering wheel will actually make a slight jerk the opposite direction from the side the bump was on. So if I hit a bump on the right side, it will give a little tug to the left.
I have replaced the inner and outer tie rods from another issue, which made a big difference. I'm going to replace my control arm bushings because they are cracked.
Any ideas what it could be? What should I check for?
I have the front torn apart right now to change my brakes pads.
Old Nov 7, 2011 | 12:03 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
i would check your sway bar bushings
Old Nov 9, 2011 | 04:20 AM
Sea240's Avatar
2001 C240
+1
If I recall, you'll have to drop the swaybar to change the control arm bushings anyways, so might as well fit new sway bushings while everything is apart. If the endlinks have undue play (likely if they are original and your car is a 2003 MY), change those too. Neither is very expensive and both generally yield very noticeable results. A good alignment after all is said and done should have your car feeling like new.
