Very Nervous... Any suggestions.
2002 C320 Sport *SOLD*, 2006 BMW 325i
I'm taking my car in on Monday to fix some kind of flap that is broken in the dash. I am really nervous because the dealer said they would have to tare the dash apart in order to get to the problem. I have a comand install from Steve, will they mess with they comand since it is not factory or change any setting so that it will not work. The problem is a loud clicking noise coming from behind the area where the key goes. Are there are precautions I need to take before going on Monday? Thanks.
I also have bi-xenons from Steve. I hope they will be ok.
'14 A6 3.0 TFSI
I don't imagine they'd do anything of the sort. They really don't have the right to. Just check it before you leave to make sure it works. Other than disconnecting the GPS antenna, I can't think of thigns they would do to alter it. Good luck, I wouldn't worry too much!
The True OG Modded out W203
Don't worry dude. If taken my car in dozens of time and they haven't said AND done anything to them. Its like when you switch rims-they don't take them off to put the stock ones back in. Are you getting anything done when Steve comes around next month?
If you are truly nervous you should see your medical professional. There are countless drugs on the market that will have you on even keel in no time.
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
Call Dr. Thorndyke at the "Psychoneurotic Institute for the Very, VERY Nervous"
(c) High Anxiety (1978)
Originally posted by Zeppelin
Wow you could qualify for the Lemon Law. You have had your car to the dealer at least 24 times - that's amazing.
OOPS!!
