p0137
Old Nov 9, 2011 | 11:34 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
p0137
i had this code after they performed the camshaft recall
now the thing is they replaced both o2 sensors for the recall
i read somewhere this code is bank 1 sensor 2 low voltage o2 sensor (p0137)
i took it back to the dealership and they said its the recirculated air flap acutator ...if im not mistaking p0239 Recirculating Air Flap Actuator but i never had this code
my car stumbles at high rpm and suffers performance
i told them about the cat rattling and pinging/hissing noises in the exhaust but they said its fine
Old Nov 10, 2011 | 08:14 AM
Glyn M Ruck's Avatar
Super Moderator
P0137 = O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
Are you sure they replaced the downstream sensor. The downstream sensor has no influence on performance. It just monitors Cat condition. Make them sort it out.
I think you might have a clogged Cat.
Old Nov 10, 2011 | 10:43 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Recirculating air flap actuator? As in, the secondary injection system?
Doesn't the downstream O2 sensor play a part in the secondary air injection? If so that makes sense that they are related.
Old Nov 10, 2011 | 10:54 AM
Super Moderator
That's a damn good question to which I don't know the answer. I thought the secondary air injection was controlled by the upstream O2 sensor. Let me scratch
Old Nov 10, 2011 | 11:04 AM
Super Moderator
I have scratched. The secondary air injection pump is controlled by the upstream sensor & NOT the post Cat downstream sensor.
Old Nov 10, 2011 | 03:50 PM
i have the readout from the dealership for the cam recall
they replaced- front and rear 02 sensors, engine harnesss, cam magnets, r & r intake manifold and supercharger, fuel injector o rings
now glen if they put on a broken rear o2 sensor...
wouldnt this mean if the cat wanted to throw a code it couldnt cause the rear o2 sensor is pretty much broke? i just feel their taking me for a ride at this point
Old Nov 10, 2011 | 07:56 PM
Super Moderator
If the Cat was bad & the after Cat sensor was buggered you would not get a Cat below specification code.
Old Nov 10, 2011 | 08:09 PM
thank you glen im gunna be taking my car in soon to a different garage or dealership
cause if they tell the o2 sensors are bad from the dealership
im gunna literally take them to small claims court
