What size can I Get
1 Post
CLK Coupe 200 Komp 53 Plate
What size can I Get
Hi ya guys tried searching but after a better answer, what sizes will fit the coupe including the offset i'm looking at 18x8 front and rear will this work, also i have a heavy boot due to a install would i be better off with 17's please help
thanks
Neil
thanks
Neil
2008 C300 Sport
Originally posted by cliffybabe
So I wouldnt need any camber kits or adjustments there just go straight on?
as long as you get the proper offset you should be fine.... you can fit 8.5" wide in the front and as much as 10" in the back
