coolant everywhere
Old Nov 18, 2011 | 11:50 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
coolant everywhere
haha today was a crazy day...i tried replacing my t stat today
and when i disconnected the hose from the t stat housing... coolant was gushing out like crazy..and i read here u only lose like a few liters
but their went my whole tank of coolant on the garage floor..at this point im pissed and freaking out
is this ok for coolant to be on the supercharger sliencer? the pulleys and everything else? i havent started the car so its gunna be drying overnight and i havent replaced the stat itself hahaha
Old Nov 19, 2011 | 12:40 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
SD3,
I would very very very gently ( a dribble) hose off the worst of the coolant from your belts & pulleys before it dries.It should not hurt the rubber but is sticky stuff & may cause slipping belts .
I cannot comment on the S/C silencer as I have not seen one.
I spilt a little when venting the system on a transverse engine & did not hose it off. It siezed the clutch to the plate ( manual trans) .
Best to clean up before it dries.
Old Nov 19, 2011 | 01:08 AM
thanks the belt didnt have alot of coolant on it...but i cleaned up wat i could see.
i did exact wat these guys did the diy... and the engine sat over night...why would the coolant gush out like that?
http://www.benzworld.org/forums/w203...placement.html
http://www.benzworld.org/forums/w202...hermostat.html
Old Nov 19, 2011 | 11:59 AM
Glyn M Ruck's Avatar
Super Moderator
JC is correct. The glycol in the coolant is safe for rubber etc. Just wash it off & dry. No harm done to anything.
Did you let the engine cool down properly & depressurize it before pulling the hose?
Old Nov 19, 2011 | 02:55 PM
yea i let the engine coolant down so it had no heat
but i didnt depressurize it
Old Nov 19, 2011 | 03:37 PM
Super Moderator
Oops! Must depressurize or it will spurt coolant all over the place. Can't have been ice cold.
