how to disconnect wiring harness from coil pack
I have an '06 C230 and am doing a change of spark plugs. Am wondering how you disconnect the wiring harness leads from the coil pack? I see the connector, but don't know what you pinch, pry, whatever to disconnect? I'm notorious for breaking those little tabs (on other applications)!
To answer my own question, you simply press on the end of the connector (there is a ribbed indentation) and GENTLY pull on the surrounding plastic of the connector. Simple stuff.
